Question about Maytag MMV5207AAS Microwave Oven
I have a Maytag microwave MMC5000BDW that sometimes work and sometimes don't. When it does not work, there is no sound at all but the timer is counting down. Please help.
MicrowaveSvc
  • 9098 Answers
SOURCE: timer will run, but won't cook
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
  • 619 Answers
SOURCE: Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Posted on Jan 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: mvp Iv microwave oven model vm12av-1
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Over the Range
When you hit Start, does the oven lamp come on but not the fan or turntable?
That would be a problem with the secondary (bottom) door interlock switch or its mount.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Posted on Aug 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag over the Range Microvave MMV5186AAS does not heat.
You have a bad secondary interlock (top door switch) or its mount is bad.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 01, 2009
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Troubleshoot maytag keypad control board
Oct 01, 2012 | Maytag Appliances Over-the-Range Microwave...
Just stopped heating, making a louder than normal sound as well is there a reset button or something I can do. all else works, pad, clock timer etc, just not heating?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 13, 2011 | Maytag MMV5156AAS Microwave Oven
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
Nov 28, 2010 | Kenmore Microwave Ovens
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
Our stovetop maytag microwave doesnt work anymore
You probably blew out the cavity thermal fuse you'll need a technician to replace it.
Aug 17, 2009 | Maytag Appliances Over-the-Range Microwave...
Doesn't cook
sounds like the heater busted.How many Watts does the microwave have?But anyway you can get it fixed by a handyman or a maytag repair man.But your better off buying a new one for around $60-$110.
Mar 16, 2009 | Sharp R-930AK Convection/Microwave Oven
Maytag MMV5207AAS Microwave Oven Logo
138 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
