Question about Sony DCRHC26 MiniDV Digital Handycam Camcorder
My sony handycam is frozen on clock set but will
My sony handycam DCR-HC26 is frozen on "clock set". It will not allow me to set the clock. It's like the touch screen is frozen. Have tried to reset, took off battery, plugged directly to wall power, recharged battery to full. It will let you record but then not playback. It goes directly to clock set, but none of the touch screen buttons work. Even tried to re-calibrate but again when you touch the x on the screen it does nothing. Like the touch part of the screen does not work all of a sudden.
  • 169 Answers
SOURCE: Touchscreen buttons not working
the flexwire is the problem of your camera, the touch screen connection is already cut..go to a service center for replacing or repairing the flexwire...is not easy for repairing that if you are not a technician that wiring is like a strand of hair that why is difficult to fix but in our shop we modified that and become more durable than the original...
Posted on Oct 19, 2007
  • 205 Answers
SOURCE: XP does'nt recognise Handycam
Hello Laura. You cannot transfer video from this camcorder with a USB cable. You will need a DV cable. This cable did not come with your camcorder. You will also need software for the transfer process. Windows Movie Maker can do this although I've never used it. I used a product called Scenalyzer. There is a free demo version at www.scenealyzer.com, but it will leave a watermark on your video if you don't pay for it. You might try Windows Movie Maker first if you already have it.
Once you have captured the video on your computer, you cannot just burn it to a DVD as a file if you want to play it in DVD players. This too requires special software.
I'm travelling for work right now, but when I get home in a few days I can be of more help. If you want to keep going on this, get a DV cable and see if you can capture the video with Windows Movie Maker and let me know.
Posted on Jan 15, 2008
ctf1800
  • 4402 Answers
SOURCE: Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Mar 17, 2008
welcomejee
  • 10594 Answers
SOURCE: LCD screen not working on my Sony handycam dcr
Usually there is flexible wire between lcd board and main board of camcorder that got broken and resulted lcd does not work.
You need to replace that flexible wire by qualified camera tech.
Thanks.
Posted on Sep 20, 2009
SOURCE: i have a sony handycam dcr-hc26 that wont close
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Posted on Nov 24, 2009
Repair handycam touchscreen
It should be the first screen you see when you turn it on, if it has not been set. This is an old camera, so the internal rechargeable battery that saves this info may be dead.
here is the manual in pdf if you don't already have it.
https://docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
Dec 27, 2013 | Sony DCR-HC26 Mini DV Digital Camcorder
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or the LCD module itself and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 01, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Hello i am hamid
I need a drive for Windows 7 Help me please
hamid.far12@yahoo.com
Jul 07, 2010 | Sony DCRHC26 MiniDV Digital Handycam...
I have replaced a Windows XP PC with a new PC running Windows 7 Home Premium and I have not been able to connect my DCR-HC26 Sony Handycam digital tape camera to the new PC. I'm using an I-link (firewire)...
Mostly with these cameras you do not need driver (unless you use a USB cable) but like me you have firewire okay? so you should unplug your camera, turn your PC off for a min or two, plug camera in THEN yes THEN put your PC on, and the Win 7 will see your camera and loads setting it needs auto ok.
May 29, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
LCD screen not working on my Sony handycam dcr hc26
Thanks.
Sep 20, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony Handycam DCR-HC26
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Aug 20, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
SONY DCR 905E handycam
Check your battery is fully charge then reset it to factory setting..
hope this may help;
dont forget to rate;
Aug 17, 2008 | Sony DCR-HC26 Mini DV Digital Camcorder
you will have to use the supplied software or just about any other video editing software to download the video to your pc. here is a link to a retail outlet for sony software.
http://www.picture-package.com/product_info.php?products_id=127
Mar 23, 2008 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony DCRHC26 MiniDV Digital Handycam Camcorder Logo
390 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
