Question about KitchenAid KUDS24SE Built-in Dishwasher
KITCHENAID DISHWASHER MODEL KUDS24SE WILL NOT START. WHEN NORMAL (OR OTHER) CYCLE IS SELECTED, CLEAN LIGHT COMES ON AND DW JUST HUMS. DOES NOT FILL OR START.
SOURCE: Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Posted on Aug 14, 2007
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Posted on Sep 22, 2007
SOURCE: Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Posted on Nov 01, 2007
  • 338 Answers
SOURCE: My kitchenaid dishwasher is making
if the water is not spraying you may have a seized up motor. if the water is spraying then you have something down in your motor somewhere..
Posted on Dec 25, 2008
SOURCE: kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Posted on Jan 20, 2009
My dishwasher is not enough with water at the start of the cleaning cycle
My new DW had the same problem but when I had a tech come to the house he explained that the DW only uses .8 gallons of water and that what I am seeing is normal. Do your dishes come out clean? My did, so I guess he was right. Good Luck...xo
Sep 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Apr 29, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KUDS24SEB3 - can't start cycle properly
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Sep 17, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Sears Kenmore model# 665-16022401 Serial# FS0304946 - Clean Light Blinking
THE HUMMING NOISE THAT YOU ARE HEARING IS THE ELECTRONIC DRAIN MTR ACTIVATING BUT YOU HAVE NO WATER IN THE SYS. SO IT SOUND LOUDER AND DIFFERENT THE HUMMING IS THE LESS OF YOUR WORRIES THAT IS NORMAL BUT WHAT IS NOT NORMAL IS THE CLEAN LIGHT FLASHING IF IT FLASHES 7 TIMES THEN PAUSES YOU HAVEA BAD PROCESSING BOARD AND ALSO A HEATER ON SOME OF THE KM MODELS THE CONTROL BOARD AND HEATER IS SOLD AS A KIT. TO VERIFY THAT THIS IS THE CASE GO TO WWW.SEARSPARTS.COM . BUT FIRST ALSO CHECK TO SEE IF YOU HAVE A BURNT WIRE AT THE HEATER ASSEMBLY WHICH WOULD REQUIRE PULLING THE DW OUT. GOOD LUCK
Mar 12, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
213 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
