Question about HP W2007 LCD Monitor
Hp f1903 flat pc monitor goes black after 5
Hp f1903 flat pc monitor goes black after 5 second
    Master:
    Sergeant:
  • 460 Answers
I was given a faulty f1703 by someone as it was out of warranty, had no help from HP and bought another brand replacement.
Same problem everyone else seems to be having. Press the on button, came on for a second or so and then went blank. Press button again, turn on again and the same happened.
I managed through trying time and again after pressing on to quickly press menu, then go down to Factory settings, press select, go down to Yes and press select again. This reset to the Factory settings and it seems to be working okay. Been like this now for about a week. I don't know how long it will last - if it goes again will try re-soldering. Guess I won't be buying HP products as this was a part of a very expensive system.
Posted on Apr 30, 2010
When i turn on the monitor it flashes on once for a few seconds t
faith1114, Try this first! See if any thing seems a little similar to your f1903 type of complaint. Problem been around a long time!!! Go do some reading here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution. After doing some reading there, you will be in a better position to make decision to DIY repair, contract out the repair work, trade in for new , DIY repair + buy a new monitor keeping refurbished f1903 as emergency spare. Here is a little clue. If unit can display Win-desktop for 2 seconds and then the "black screen of death happens" you certainly need to do some reading and viewing of DIY videos at YOUTUBE so you can understand the big problem all major CCFL back-lit lcd monitor manufacturers are facing. do some additional reading here at fixya in the profiles of ccfl backlit lcd monitor technicians "budmrtn" "buddymc" , "12fixlouie" (late) "louie12fix" (old) Follow links you find there. Once you understand basic problem you will never walk past the new curlie-Q, screw-in energy-efficient CFL light bulbs at the local hardware or big box homecenter ever again with out having a slight grin on your face!! Bye for now. 12fixlouie
Jun 02, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Upon Start Up my Monitor flickers on for just a second when the blue screen appears, then it goes black. I have to reboot many times before it comes on. I've reset power settings, updated driver for the...
Try it on another PC to narrow down the problem. If does the same on another PC, then you need to open it up and inspect inside the unit, first thing to look for will be capacitors with bulging top/seal or leaking, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 23, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
No picture
Hi
You have parts on the power supply board which are going bad. You can send it to a company like mine or take it to a local repair person.
Aug 05, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 turns itself off when connecting DVI
Sounds like your problem is hardware and lies with the port on your PC, this may be due to a bad driver, or bad port! Sounds like you have tried everything else!
Oct 03, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP W2007 LCD Monitor Logo
167 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
