Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Icemaker not producing ice
My ice maker is not producing ice
  • 33 Answers
It's fried go buy a new one they don't last very long and it's a 100 fix
Posted on Apr 29, 2010
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Tip
    How to install/replace Icemaker in top bottom fridge
    Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
    on Aug 01, 2011 | Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    The icemaker is not producing ice. Water is not going into the icemaker to produce the ice.
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Oct 30, 2010 | LG LSC26905 Side by Side Refrigerator
    Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
    the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
    Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
    ICE MAKER GETS COLD-DOES NOT PRODUCE ICE
    Hi
    Try turning the thermostat to a lower setting. (warmer) It might be set too cold and the thermostat isnt being satisfied. Usually this is all thats wrong with it. Temperature in bucket between 10-15 degrees.
    Jun 08, 2009 | U-Line Icemaker
    Icemaker does not make ice. Appears no water is getting to maker.
    If your ice maker has stopped producing ice completely, check these, in this order:
    • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
      • If your ice maker has a small red plastic lever, lower it to lower the wire.
      • If there's no plastic lever, simply lower the wire.
      In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
    • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
    • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
    May 20, 2009 | Refrigerators
    Replaced icemaker with new one but still not working
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
    Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker will not was dispense ice
    My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
    Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
    126 people viewed this question
    Top Fisher and Paykel Refrigerators Experts
    Brian Coughlan
    John Tripp
    John Tripp
    Colin Stickland
    Colin Stickland
    Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
