Question about SanDisk Sansa e260 MP3 Player
Downloading songs i tried using rhapsody, but whenever i go on, while scanning the tracks, it stops at 15, then my computer freezes, then my sansa freezes and i have to let it die out. rhapsody used to work before, but now, for some reason, it won't anymore. i don't get it, so if you could help, it would be amazing!
  • Ryancarp18 Mar 31, 2008
    I get my music of of limewire and send them to rhapsody. Rhapsody will not ready my sansa's music, won't add songs either. nor will rhapsody disconnect my sansa. What do i need to do to fix this?
Try to use lime wire. it works for me. of course you have to have windows media player up too. plug it to the computer and drag the downloaded songs to the sync place.
Posted on Mar 31, 2008
SOURCE:
When on click on my sansa e260 in Rhapsody I see
Try the following method to see what is on your Sansa e260
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
If you want to delete some or all of the files do the following:
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 29, 2009 | SanDisk Sansa e260 MP3 Player
Can't find clip in my computer
This is and excerpt from "EphMusicFan" on the Real player forum. Original link is also below.
" The following steps finally fixed everything for me. While it may seem long, it only takes about 15 minutes and should fix everything.
If you run windows XP don't have Windows Media Player 11 installed, download and install it here,
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
Run Windows Update, and install all high priority and optional updates related to Windows Media Player or device synchronization.
On XP, the updates include:
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows Media Player 11 for Windows XP (KB939683)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Open Rhapsody
From 'My Account' menu select de-authorize computer
Close Rhapsody
To delete the mcs.rma file:
1. Close RealPlayer/Rhapsody
2. Click the Windows Start button. Then click Run.
3. Type %windir%\system32\ and click OK.
4. Find the mcs.rma file.
5. Right-click mcs.rma and select Delete.
6. Close the window.
To delete the basi3260.dll file:
1. Open the My Computer icon on your desktop.
2. Open the C: drive (usually Local Disk (C:\)).
3. Open the Program Files folder.
4. Open the Common Files folder.
5. Open the Real folder.
6. Open the Plugins folder.
7. Find the basi3260.dll file.
8. Right-click basi3260.dll and select Delete.
9. Close the window.
10. Restart your computer.
on sansa Clip itself, disconnected from computer, go to settings, then choose format
Make sure Rhapsody, Windows Media Player, and all other media programs are closed
download firmware
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=2946 (make sure you get 'Americas' firmware version)
unzip firmware file
connect to computer
drag firmware file onto sansa Clip icon in Windows explorer
wait to finish all copying (Sansa Clip screen will say connected, not writing or reading)
disconect
firmware updates on device, then it shuts off automatically
turn it back on
reformat from device (settings menu, format)
put in msc (under USB mode on settings menu)
reconect
open sansa Clip E:/ in Windows explorer, delete all files (should be 6-8 folders and files in top level directory of Clip)
reformat from windows explorer (right click, format, (FAT file system, NOT FAT32))
disconect
put in mtp (under USB mode on settings menu)
Open Rhapsody
It will run through quick setup again, due to files deleted before.
'Reathorize Computer' (under 'My Account' menu)
"Update Track Licenses' (same menu)
connect to computer
wait for Rhapsody to fully load clip (may take 30 seconds)
reformat from rhapsody (right click on sansa clip icon in rhapsody, select reformat)
hold down control and shift buttons at same time, right click on sansa clip icon in Rhapsody, select 'reset secure clock'
right click on sansa clip icon in rhapsody, select authorize device
wait while sansa clip updates (wait for screen of device to say 'connected' for a while, rather than writing or reading)
disconect
reconnect
wait a while updates finish
disconect
verify acount, and dates on device, under setting menu, account
should say renewed (with today's date) expires a date 30 days later.
download one new track from rhapsody you never have downloaded before
reconect
transfer that one track to clip
wait for all updates to finish
disconect
verify account, dates on device, check that the track plays properly"
Hope that helps.
http://real.lithium.com/real/board/message?board.id=InstallingRhapsody&thread.id=26724
Feb 05, 2009 | SanDisk Sansa Clip MP3 Player
Player stopped working with rhapsody
Uh, I had a similar problem which was extremely difficult to solve. What you want to do is reformat your entire MP3 player. YOU WILL LOSE ALL THE MUSIC ON YOUR SANSA. But you can simply resynch it.
http://mp3support.sandisk.com/tools/DeviceRecoverySetup.exe
Aug 23, 2008 | SanDisk Sansa e260 MP3 Player
E-260 freezes when computer is trying to read it in Rhapsody program
I read some of the other post and found that I needed to use Windows Media Player. I had the Rhapsody program on my computer as well. Once I downloaded Windows Media Player I was able to access the files and add and delete songs.
My husband is not a big fan of Media Player. Lets hope I haven't done anything that he will have to fix. :)
Good Luck.
Aug 10, 2008 | SanDisk Sansa e260 MP3 Player
Sansa c250 and rhapsody
I first suggest that you use Windows Media Player on transferring songs to the player. Rhapsody is a p**n in the a** when i use it to transfer songs to the player. Well back to the topic, make sure the device that you have is set to MTP when you are transferring songs to the player using rhapsody.. If it will not transfer format the player using Settings and then FORMAT if it did not work format the player in MSC mode. To do this, go to settings then to USB MODE then change it to MSC and then connect the player to the computer. After connecting the player to the computer ti will be detected as a removable disk drive. Right click on it then choose FORMAT make sure the file system is FAT32. THen after the format is done. Chnage the mode back to MTP then transfer a song using rhapsody. If all else fails using the windows mediaplayer program. Here are the instructions on using the windows media player program.
http://www.sandisk.com/Retail/Default.aspx?CatID=1468
Aug 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Rhapsody problems
what happens when you drag one track at a time .
it sounds like you have a a disk error
try erasing and reformat drive
that will clear up all problems
richard from chicago
Apr 05, 2008 | SanDisk Sansa e200 MP3 Player
Freezing
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 22, 2007 | SanDisk Sansa e200 MP3 Player
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E260
Resync using Windows Media Player instead.
Aug 14, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e250 keeps shutting down
try and see if it is in MY COMPUTER if it is there download the newest firmware and update it if that doesn't work uninstall the mp3 player from your computer and then installit again.
May 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
