Question about Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout ....
Trying to remove the cartridge on a moen 7730 single handle fauct it won't budge. I removed the retainer clip and was under the impresion that i had to just pull it out but it will not come out. thank you.
  • 299 Answers
Once the clip is removed it should pull out but they can be stubborn sometimes. You might want to clamp the stem with a Visegrips and yank away.
Posted on Apr 30, 2010
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
What is wrong with my single handle shower fixture in that it does not give out enough hot water
This is a common problem with Moen shower valves and fairly simple to fix. The pressure balancing cartridge is sticking inside. You need to remove the cartridge and clean it with white vinegar. The problem appears in valves that are not used very often - like in a guest room shower. The impurities in the water leave a varnish-like residue that causes the element to lock up and restrict hot water flow. If you are the original owner Moen will send you a free replacement cartridge but cleaning the one you have will do the trick. Once it's working be sure to run the hot water at least once a week. Here's how to fix it:
1. Turn off water supply to the house or at the PEX panel if you have one.
2. Remove handle by loosening the set screw at the bottom of the handle and pulling off.
3. Remove escutcheon plate by removing 2 screws on the face.
4. Remove escutcheon tube surrounding the valve by pulling with a needle nose pliers.
5. Using an awl or small screwdriver pry the retaining clip up and remove - DON'T DROP IT behind the tile!!
6. Using a pliers, pull out the cartridge. If it won't budge you can try some WD-40 or PB Blaster and if that doesn't work you'll need to buy a "Moen Cartridge Puller" (about $13 @ Home Depot) and it will come right out.
7. Shake the cartridge. If it does NOT rattle you've found the problem. Soak it in white vinegar for 15 minutes and try shaking it again and repeat till you hear the pressure balance element move back and forth. A shot of PB Blaster also helps.
8. Once the element is moving freely you can reassemble everything by working in reverse - don't forget to reinstall the retaining clip or the cartridge will become a missile! TIP: To prevent dropping the clip tie a string through the hole in the top and tape the other end to the wall. If it slips you can just pull it up. Also, spray a little PB Blaster in the valve body before inserting the cartridge to make it easier to seat it.
Hope this helps!
Sep 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Where is the retaining clip on older Moen kitchen one handle faucet? I have a parts diagram and do not see anything to pull out on metal holding down cartridge. Thanks
it should be under the pivot nut /collar,(where you remove handle from.un screw it and look closely.it is shaped like a horse shoe and may have small hole in it,and is brass in color
Apr 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
I am trying to replacr the cartridge on a 7310
You need a Moen cartridge puller or a plumber who has one on his truck.
Mar 14, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
Dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Nov 27, 2008 | Plumbing
Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Logo
585 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
