Money stuck in front load washing machine
I know it's my fault.. but i have washed a item of clothing that still had money in it. the money has now got stuck in the middle of the 2 tubs (i think) or something like that. I can hear the money in the washing machine. My problem is i know have to pay a few hundred dollars to get it fixed as they have to pull the whole machine apart. is there a easier solution. is the money safe to stay .. it's a maytag front loader.. not sure the name
  • 6 more comments
  • monika75 Mar 24, 2008
    Great.. At work at the moment. so i don't have serial number on me, but will get it ASAP
  • monika75 Mar 25, 2008
    Sorry it's a MAF1375AAW
    It's a maytag MAF1375AAW. Front loader
  • monika75 Mar 28, 2008
    I can hear it.. I know someone that had the same problem and it did so much damage it was unreappairable.. i don't want this to happen to me.. how long will it take to go through the pump..
    when you say clean the pump do you mean the filter
    thanks.. but i'm really to scared to do a load for it to get there.. i don't want to ruin my machine as this is not covered by warranty.
    it worked.. problem fixed.. it spun it one way and nothing.. i spun it the other way and a 5c dropped into the machine.. Can you explain this by any chance.. why it didn't go into the filter and maybe you could answer another question. while investigating my problem i came across a lot of unhappy people with their maytags front loaders. one lady said she got maytag to buy hers back as they are no longer making this model and any parts for it. do you know if this is true
  • robert samples May 11, 2010
    no you dont have to pay a few hundred to get it fixed open the door and give me the model number off the serial plate and we will fix it
  • 1,314 Answers
What brand of washer is this
Posted on Mar 25, 2008
  • 2 more comments
  • robert samples Mar 28, 2008
    ok now why do you think it has money inside the tubs are you hearing sounds or what and if its in between the inner and outer tubs it really wont hurt any thing and should go to the trap in the pump we may need to clean the pump
    yeah the filter is what they call it
    look open the door and with the power off spin the tub by hand and see if you still hear it spin it hard
    you dont have the model they are talking about and check your pockets before you wash to prevent this in the future and dont i get four stars bark bark for saving you hunderds lol i just a poor little helpless seal with big brown eyes
Why is water level low for Samsung VRT Top-Load washing machine
You may have to get someone to change the water level that's at the top of tge washing machine...
Jun 29, 2014 | Samsung WF337AA Front Load Washer
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Washing machine model WCSE 416OB is making a loud noise when spinning and not fully wringing the water out of the clothes--what could be the problem?
I fyou have a well balaced load and it is not banging side to side or doing the wash machine dance then it is probably the trasnmission or coupler. IF you want to spend some money or lots of money to have it replaced it's up to you it wouldnt hurt to have a authorized techichian take a look at it. If it is and it is nt worth fixing then take a look at a front loader wash machine you cant go wrong with one of those as it gets more water out of your clothes which means less time int the drier and saves you allot of money.
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
Smelly clothes
It is because of the front loading door..
It seals shut - so after you do a load and shut it,, midew forms in certain areas..
Run a white load and use bleach..
After wash - (as all washes) leave the door open..
This might have to be repeted a few times - but it WILL go away..
Remeber to leave the door open after every load..
Have a nice day ;o)
Aug 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The seal around the door molds. And my clothes
Just send me your $19.95 and I'll share my secret with you!!!
Jun 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag MAF 1675 showing an 'Error 2' message
sounds like money, well it might just be money
probably money stuck in the pump
Jun 11, 2009 | Washing Machines
Where is the pump on a whirlpool make washing machine?
remove the panel on the front bottom of your unit. it is the only panel you will see. Inside you will see a white pump unit with a cap that can be unscrewed. Once you remove it, water will drain all over so make sure you have something to catch it in and you will also get allot of junk out with the water. I found nails, money and other items when I cleaned mine out.
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Elastic eating front load washer
Check the inside drum vanes. Sometimes the vanes may crack and grab certain items.Next check the front of the drum and tub for any loose items like wires from bras or curtains sometimes these may get stuck in the drum or vane and cause this problem.Also check your soap make sure there is not alot of suds this is my number one problem with these machines.H.E. soap is best but watch liquid tide it's been sudsing alot.
Oct 03, 2007 | GE WSXH208A Front Load Washer
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Open Questions:
Frigidaire GLTF2940ES3 washer cycles/controls out of whack since replaced main control board -- is there a compatibility problem with our 11 year old washer? Bought washer in 2007, Frigidaire GLTF2940ES3. Stopped working, got error code suggesting problem with main control board, so replaced it with new, part# 137006000. Didn't fix problem, got new error code suggesting problem with speed control board. Replaced that with new, part# 134743500. Now washer works at least, all the cycles we've tried do something plausible, but the controls and cycles are out of whack. For example, when I set the dial to normal, it used to show 52 minutes in the display, now it shows 28 minutes. When I set the dial to heavy, it used to show 56 minutes in the display, now it shows 52 minutes. Did they rearrange the dial since 2007? If so, is there a key we can use to translate new dial labels to old dial labels? It seemed like there was only one way to assemble the knob and dial, so I don't think I put it together with the dial in the wrong position. Or is this a common failure indicating that the new main control board is defective? Easy to imagine a defective control board causing one or more cycles or controls not to work; hard to imagine a defect that results in the case we have, i.e. everything working, but cycles scrambled. Our laundry room is tiny and we've got the dryer stacked on top of the washer, so it's a major hassle to get at the main control board major hassle like can't get into the refrigerator or use the back door of the house while the laundry machines are un-stacked. Otherwise I would swap the old one back in and see what happened. Any thoughts or suggestions welcome! Thank you.
Mar 18, 2018 | Frigidaire Washing Machines
Washing Machines Logo
423 people viewed this question
Top Washing Machines Experts
