Question about Microsoft Office Publisher 2003: Complete Concepts and Techniques (Shelly Cashman) (0619200316)
How do I hook kup a 36 volt battery to the motor?
How are the batteries properly connected
Depends on what voltage you want. Take 3 twelve volt batteries and hook the up positive to positive. And the negatives to negative. You still only have twelve volts, just a lot of amperage. Hook the same 3, positive to negative. Then you have 36 volts.
Oct 06, 2016 | Cars & Trucks
CAN i CHARGE A 36 VOLT BATTERY WITH A 24 VOLT CHARGER?
No of course not.
The charger has to be the same as the battery it is charging. On BIG batteries, it also has to have the power to handle the higher amps as well.
  • 36 Battery Charger Volts - 36 Battery Charger Volts - Deals! Ad · www.HomeGardenPro.com 36 Battery Charger Volts - Deals! Your Home, Your Style - Redefined.
    Handpicked Collections · Great Deals - Low Prices
  • 36 Volts Battery Charger ' Calibex.com Ad · www.Calibex.com/Electronics Cheap Prices and Huge Selection 36 Volts Battery Charger on Sale!
  • 36 volt battery charger in Batteries & Chargers ' eBay www.ebay.ca > Search > 36 volt battery charger Find 36 volt battery charger and 36 volt battery from a vast selection of Batteries & Chargers. Get great deals on eBay!
  • 36 Volt Battery Charger ' eBay ebay.com Find great deals on eBay for 36 Volt Battery Charger in Forklift Batteries and Chargers. Shop with confidence.
  • 36 Volt Battery Chargers ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Chargers in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Chargers - Electric Scooter Parts www.electricscooterparts.com/36vchargers.html 36 Volt Battery Chargers for Electric Scooter, Bicycle, Pocket Bikes, and Go-Karts. We have 36 Volt (36V) battery chargers in stock.
  • 36 Volt Battery Charger ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Charger in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Charger eBay
    Sep 20, 2016 | Health & Beauty
    How do you test a motor when you got it out of cart 36 volt
    3 -12 volt batteries in series gives you 36 volts
    Nov 17, 2015 | Cars & Trucks
    I've bought (at auction) a Marketeer 36 volt electric truck (similar to what you see pulling luggage carts at airports). Before spending money to buy 6 new 6 volt batteries, I'd like to know whether the...
    I doubt your understanding of how the motor works is correct. More likely 2 of the terminals on the motor are for the field coils. The battery charger should not be used directly to power the motor without a battery also connected. The motor would function as a short circuit to the battery charger.
    Instead, you can use 2 car batteries to test if the motor works. The full 36 volts is not needed.
    Sep 16, 2013 | Dryers
    Hooking up a 36 volt charger to three 12 volt batteries in series
    first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
    Aug 29, 2013 | Minn Kota Boating
    I have a motor guide great white saltwater series 109 lb thrust 36 v trolling motor. I hooked the 3 batteries up right but it isn't running right, it's very slow. What do I do with the grey wire which has...
    running to slow indicates voltage too low
    you will have 3 X 12 volt batteries connected in series ( positive to negative to positive to negative with positive to motor The first battery negative connected to the ground on the motor
    the multicore wire cable is for 12 volt draws as in fish finder, light etc and can be connected across any single battery terminals
    They could also be for a foot controlled pedal that is forward and reverse operation
    that will be explained in the user manual
    Dec 06, 2017 | Car Audio & Video
    How do i hook up the 3 12 volt batteries for 36 volts
    Not sure why you need 36V but here's how.
    <--P---N----P----N----P----N------>
    Bat 1 Bat 2 Bat 3
    You basically string them together. If you put a voltmeter on each end of the group you should have 36 volts or near it depending on the charge of the batteries.
    Mar 13, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Mini moto atv 36 volt will not run
    it probably is the interlock switch/ the black square with 2 small green wires and to large reds.replace that and should run.just bypassed mine and know it works.have fun
    Oct 12, 2009 | Jeep 36 Volt Battery for Minimoto ATV, Go...
    Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
    To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
    This is only a solution for 3 battery system.
    For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
    budman772357@embarqmail.com
    Mar 01, 2009 | Minn Kota Boating
    Microsoft Office Publisher 2003: Complete Concepts and Techniques (Shelly Cashman) (0619200316) Logo
    18 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
