Question about Sony Cybershot DSC-T200 Digital Camera
The flash won't work under any setting I find.
  • 87 Answers
Try changing it to single picture mode, if cammera is in burst mode the falsh is forced off.
Posted on Apr 29, 2010
  • 3 Answers
I had the same problem.
1. Touch "menu" then under the "rec mode" change from Burst to NORMAL.
2. Touch the flash icon and, then, it will be possible to turn the flash on...
Posted on Jul 28, 2010
Canon pc1251 won't take picture with flash on. it will if i turn off flash
Check if your camera is on automatic. Then f there is too much light it won't work. To use a flash for fill in, you have to be on a scene mode. Check the manual. If the camera has a flashing light, indicating the flash won't work, you have a serious problem.
Dec 10, 2014 | Canon Cameras
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
Dec 25, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
LG Rumor Touch flashing red light won't work
Open menu and check the settings, open settings and scroll under the lights and it must be switched to ON.
Jul 04, 2012 | LG Rumor Touch
My nikon D-80's flash won't pop up, yet it also won't go past the flash sync speed of 1/200 while flash is down
Was the camera impacted? Sound like the flash up switch if always closed. Remove battery. If you carefully remove the flash cover (two screw underneath) by first inserting a business card under the flash on the rewind side (yeah, we haven't come up with a better term!) at the back and slide it forward freeing the flash down latch), and do not touch the flash tube as there is 300 + volts across it if it is charged!
Look at the pivot for the flash on the release button side at the back, you will see a small switch. the top part may be under the activating rod - reset it above the rod and it will now work properly
Once again, be careful - there are 300 volts across the flash tube if it is charged
May 06, 2012 | Nikon D80 Digital Camera with 18-135mm...
My bulbs are new in my passenger side flashers work but my driver side won't 1986 monte carlo
did you check the flasher unit under the dash? if the light bulbs come on on drivers side, but do not flash, then its the under dash flash unit
Apr 25, 2012 | 1986 Chevrolet Monte Carlo
Panasonic DMC-Z28 - the flash button does not call up a flash setting menu and so the flash won't turn on.
Is your Z28 set up to do burst shooting as this will stop the flash working, click on the trash button and turn off the burst shooting. Hope this helps.
Feb 12, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
My Sony Steady Shot DSC-S950 won't flash. I have pressed the flash setting several times as suggested in blogs to no avail.
Sep 15, 2011 | Sony Cybershot DSC-S950 Digital Camera
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
209 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
