Question about RCA L26WD26D 26 in. LCD TV
How to use the auto shut off feature? - RCA L26WD26D 26 in. LCD TV
    Problem Solver:
  • 10 Answers
Its in the menu selection but some tvs dont have it
Posted on Apr 29, 2010
How do I reprogram my platinum Keurig so it does not shut off
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
Nov 25, 2013 | Keurig Platinum B70 Coffee Maker
Turned off can not restart
it has an auto shut off feature if the motor gets to hot try unplugging it wait 30 mins then try again
Jun 02, 2013 | Eureka AirSpeed Pet Bag Upright Vacuum
Remove shutoff feature
You shouldn't remove the auto shut off feature, it is a safety mechanism, and it will increase the life of the gun. It is also very convenient because you won't put the gun down and come back to find it in a pile of melted or hardened glue
Jan 16, 2013 | Stanley Glue Gun Contractor Grade Auto...
Got hot no water/add water while running/quite running
Auto shut down shuts your fuel off its a safety feature.. so it will not blow up if you get in a wreck...
Nov 06, 2012 | 1992 Dodge Dakota
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1000 shuts off on it's own
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
Dec 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Monitor shuts off and on
I had the same problem, so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Dec 13, 2008 | E-Machines T6520 PC Desktop
Can I disable the auto shut-off feature on the JVC Everio?
doesn't seem to be a function to disable sleep mode.
Oct 01, 2008 | JVC Everio GZ-MG21 Camcorder
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
RCA L26WD26D 26 in. LCD TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
