Question about Samsung SyncMaster 203B LCD Monitor
Shadows form to the right side of every object on the screen. possible cause and solution?
  • 61 Answers
Make sure powers off,
Move monitor cables, ck connections.
Posted on Apr 30, 2010
Testimonial: "I had previously realized that one of the cables attached to the monitor was not fully seated. So the Expert was right on."
Picture adjustment guide form a 32" LCD TV Dark Spots, shadows, etc. Thank You!
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 24, 2016 | Toshiba 32AV500U 32 in. LCD HDTV
LG MODEL 55LM4600 THAT HAS A VERTICAL SHADOW ON THE RIGHT SIDE OF SCREEN ABOUT 3 OR 4 INCHES WIDE. hAVE YOU HAD THIS BEFORE?
Line fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 03, 2015 | LG Televison & Video
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Cameras
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Hitachi 61" TV-objects on screen have yellow shadowing
The convergence circuit of the TV is causing this. You will need to have your convergence output ICs replaced. Expect to spend $350-450 to have this issue fixed.
michtech
Feb 12, 2009 | Hitachi 60UX58B 60" Rear Projection...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Colored shadows on sides of subjects
Convergence problem... most likely caused by convergence ics
Jan 18, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi WD-62827 Problem
Uh Oh! Unless this is something simple like a loose piece inside the projection chamber shadowing the screen it would have to be the light engine ($$$) warping due to overheating of its plastic housing. Check inside the cabinet for loose objects in front of the lens, then clean all the fan filters, then call your warranty company.
Hope Ya Fix It!
Jan 15, 2008 | Mitsubishi WD-62827 62" Television
Samsung SyncMaster 203B LCD Monitor Logo
249 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
