Question about Neso Technology Pixo A700 17 in. Flat Panel LCD Monitor
When i install vista and upgrade video driver moniter unable to display resolution pixo a700 moniter
  • 348 Answers
Press f8 and keep pressing untill menu appears tjen highlight on enable vga mode and press enter your problem will be solved if you want to see high resolution then insert an AGP card into an AGP slot then you can see high resolution use 8X AGP card for better result
Posted on Apr 29, 2010
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
Unable to install driver and error it says is monitor resolution atleast it should be 800*600
This sounds familiar. What you need to do is download the motherboard INF setup or the motherboard drivers as they are sometimes called. Run that and windows will then be able to identify the hardware. At that point you can run the video driver and it should now install. When it is running you can change the screen resolution to higher as well as the colours to higher.
As a word of caution sometimes the drivers that you download from the manufactuers website won't work for the first install but the ones on the cd will.
Aug 11, 2010 | Gigabyte GA-8LD533 Motherboard
My compaq 5500 monitor is not changing its resolution
The video driver may have reverted to a standard VGA driver or your
video driver has stop working and needs reinstalling.
Sep 20, 2009 | HP Compaq MV 5500 15" CRT Monitor
Auto sync appears to not work properly
The projector does not recognise a vista display res. Change the pc to the native res of the projector for best results
May 19, 2009 | BenQ PB8250 Multimedia Projector
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Hello
You need to install the video drivers for your computer before you can get your resolution and colors back. Go to your computer or motherboard or video card manufacturer's website and download the vista drivers for it and install.
Jul 20, 2008 | Philips 170P 17" LCD Monitor
Blurred pictures on monitor
The problem is not the monitor, it is the display adapter (Video card) of your system needs a valid Vista driver. (NVidia, ATI and Intel are the 3 largest Graphic card manufacturers) Monitor drivers are almost never needed except on some advanced large LCDs.
You said up upgraded to Vista, did you use a Vista upgrade DVD or just perform a clean installation of Vista? Have you installed Vista Chipset drivers? The chipset and Graphics drivres may not be native to Vista, you may need to install them.
Jul 05, 2008 | Proview PL926WBi 19" LCD Monitor
Neso Technology Pixo A700 17 in. Flat Panel LCD Monitor Logo
74 people viewed this question
Top Neso Technology Computers & Internet Experts
David Payne
David Payne
Are you a Neso Technology Computer and Internet Expert? Answer questions, earn points and help others
