Question about HP LaserJet M1120 MFP All-In-One Printer
HP LJ M1120 SCANNER ERROR 20 HOW CAN I SLVE THIS PROBLEM
    President:
  • 2,049 Answers
According to HP Tech manual, it says...
20 Error/Memory overflow: Applies to all Laserjet printers
Add more internal printer memory or too much data or data too complex, simplify the print job and retry.
Posted on Apr 29, 2010
Scanner 20 errer
Posted on Jan 18, 2011
This does not tell me how to get rid of the error message!
Posted on Aug 05, 2010
4 Suggested Answers
SOURCE: scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Posted on Jan 14, 2010
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
  • 304 Answers
SOURCE: how to cold reset the hp lj m1120 printer
No cold reset for this model.
Only Restore default Option.
Restore the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults.
1. On the product control panel, press Setup.
2. Use the arrow buttons to select Service, and then press OK.
3. Use the arrow buttons to select Restore defaults, and then press OK.
The product automatically restarts.
Posted on Jul 08, 2011
Scanner error 20 & scanner error 6 came in disply
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize. If a surge protector is being used, remove it. Plug the product directly into the wall socket. Use the power switch to turn the product on. If the error persists, contact HP. See www.hp.com/support/ljm1120 or the support flyer that came in the product box.
Sep 20, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 6". How to fix it up? Thanks!
This means that the scanner sensor is facing some issue so that it is not able to initialize the scanner sensor.
Is you scanner working fine?or you are facing any issue while scanning documents?
Sep 10, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Hp laserjet 1120n mfp showing scanner error 20 all the time its on
Open flat bed glass, take out CCD unit check the mechanism broken/gears warn out? replace the CCD unit..
Sep 08, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I changed fuser unit after which the printer began to show scanner error 22 each time i on it. What is the possible solution?
Hello zeksvc,
The "Printer has an internal Hardware problem!"
To try to fix the 'error', do the following:
Turn-off the "Power" to the Printer.
Next, "Shut-down the computer.
"Unplug the Printer {only} from the 'Wall Outlet'.
"Disconnect the [Cables from the Printer to the Computer]."
Now, 'reconnect the cables'.
*Note: If you are using a "Surge Protector" with the Printer?
Plug the Printer 'directly' into the 'Wall Outlet'.
Turn-on the Computer first!
Next, turn-on the Printer.
"I hope this fix the 'error' problem."
*Note: For more information about your "Printer."
I've given you a "Link" to download a {Service Manual}.
There may be useful infomation to guide you in the future!
If you need help with anything else?
Write a 'comment', I'll be standing by, to assist you!"
"Best Regards"
Click here for "Manual" http://printerschematic.com/wp-content/uploads/hp/HP-LJ-M1120-MFP-Manual.pdf
Jul 26, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Lazer jet M1120 MFP scanner error 22
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 20". How to fix it up? Thanks!
Nov 03, 2010 | HP LaserJet M1120 MFP All-In-One Printer
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6 in hp laserjet m1120 mfp
Cable may not be connected correctly, try reconnecting the scanner cable. Or the scanning software is corrupted. Try uninstalling and reinstalling the software. Did your scanner ever work?
Jan 08, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
HP LaserJet M1120 MFP All-In-One Printer Logo
3,484 people viewed this question
Seeker5211
Seeker5211
