Question about HP Pavilion dv4000 Notebook
Typing problems, it skipes lie middle nad generally tythmps to gjups around, u see here
  • tiefindanite May 11, 2010
    if you have a smartphone, repost question
  • 54 Answers
Did u check it in the command prompt? if its the same in CMD then its a h/w fault. check it out.
Posted on Apr 30, 2010
Nad t753 volume control knob doesnt work
I'm going to assume that you mean it jumps around, volume up/down by itself? If so, you have a bad rotary encoder. If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Aug 29, 2015 | NAD Audio Players & Recorders
How do I get skipe up
Type skype.com. in your search browser, load it and follow the prompts
Sep 16, 2014 | Computers & Internet
'my 2005 jetta keeps skiping
The following are the general instructions on the start of diagnosing any electronically controlled engine or transmission problem.
The engine and the automatic transmission (transmission control is only for automatics, engine is still computer controlled no matter the transmission type) in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems. Also engine mechanical problems can and do cause many drive-ability related problem such as rough idle and other symptoms.
Oct 26, 2012 | Volkswagen Cars & Trucks
Hi there .. i have a nad t752 amplifier , i have just got it back from the nad repair shop , they have just reinstalled it , but now the front right speaker is much softer than the left front speaker ,,...
I hate to say this but the repair was not complete. If the sound levels are different with the balance in the middle, then either they missed a problem in one of the pre-amp stages, or they used an incorrect substitution for transistors in one or more stages. This unit should be brought back to complete the repair.
Any additional detail would require that I see the actual unit and poke around inside with test equipment.
Dan
Aug 08, 2010 | NAD T752 Receiver
I have a old NAD 1300 pre amp. I need to replace the volume rheostat where can i buy the part?
Hi, for the price of servisol you may as well buy a brand new pot. The nad uses a dual carbon pot. Any electronics shop should have one.
Is it a pcb mounted type or one with loot solder tags?
A couple of quid, but if you want to upgrade, then spend around a tenner and get an alps conductive plastic pot.
Try this:-
http://www.rapidonline.com/sku/Electronic-Components/Resistors-Potentiometer/Control-Potentiometers/Professional-audio-potentiometer/65228/66-0225
OR:-
http://www.maplin.co.uk/Module.aspx?moduleno=2207
Have a look on ebay, there should be loads.
Just found this mod.
http://www.diyaudio.com/forums/attachments/solid-state/69062-replacing-nad-1300-volume-balance-pot-nadmods.jpg
If you need more help, give us a shout and i'll try harder :)
Regards - Anthony
Feb 11, 2010 | NAD C320 2-Channel Amplifier
Paper jam
take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
Aug 01, 2009 | Brother HL-2070N Laser Printer
NAD 302 PHONO STAGE
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Jun 26, 2009 | NAD C372 Amplifier
Re: NAD 3150 speaker "clips"
Yes these clips can be replaced. There are a number of suppliers on the net that provide speaker parts. Look around and find one that will fit. As long as the hole is filled (no gaps) the speaker integrity won't be broken. The exact shape is not important. Figure on $2-$5 for the part. If you are looking for the specific NAD part, that will be a bit more difficult. I'm assuming that the clips are on the speaker not the receiver. If hte clips you are talking about are on the receiver end, this gets a bit more complex. Try calling NAD service and ask for the part. It may not be cheap, but there should still be some around.
Dan
May 22, 2008 | Audio Players & Recorders
NAD C370 in protection mode
With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
Dariusz70@verizon.net
Feb 10, 2008 | NAD C370 2-Channel Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
HP Pavilion dv4000 Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
