Question about Fisher and Paykel GWL11 Top Load Washer
No lights on the panel and nothing works when start is pressed. water got in the panels. what to do? when i pushed the lid lock button there was a loud pop and everything quit.
  • 33 Answers
Replace control board
Posted on Apr 29, 2010
I turn my machine on the lock light is on plus the drum clean & cottons lights are on, try to turn the lock off &bit won't.Perhaps it needs a drum clean but nothing will work
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
May 25, 2015 | Fisher and Paykel Washing Machines
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Lid will not lock, Washer will not start: I press
There might be the issue of the lock as the control board tries to send signal to close the lock but it can not. This is common issue with the lock more than the control board.
Oct 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Lights come on but nothing happens when I hit the start button?
Hi just read your posting.Now just a couple of questions.When you push the start button does it make a beep noise?Do the other buttons work?Have you tried advancing the cycle to spin and pushing the start button?This problem could be a faulty display board or faulty lid switch,or water valves.Please reply with additional information on the questions and I am sure we can rectify this fault.Does your machine have a lid lock light and an Efficiency option button.Looking forward to your reply.
Jun 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Zanussi aquacycle 1000 start pause button
investigate the water inlet cold water inlet valve
Feb 28, 2009 | Washing Machines
Kenmore top load washer model 110.44722401 won't start
The Machine does not know the lid is shut.... there is an arm connected to the lid... that arm runs just inside the the top cover and presses a button to signal the lid is down.. some where along the line the arm isnt pushing the button..take off the top cover and it should be an easy fix
Sep 06, 2008 | Washing Machines
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
101 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
