Question about Simplicity Denim Star SW210
Propeler foot so im pretty new at sewing but i got this product and its pretty good but the foot (the part that holds the fabric down when your sewing) is really jiggly when it is not down. also i "propeller" under the fabric that is suppose to make it move doesnt do anything. So i have to pull my stuff through verses it feeding it to me. also i los tthe manual so that just makes this harder
  • 3 Answers
I'm pretty new to sewing as well, but have you checked to see if your feed dogs are up or down? If I am correct (little teeth on the sewing plate right under the needle)they are what moves the fabric along for you. If youre free sewing or quilting you'd want them down but not for regular sewing.
Posted on Apr 08, 2008
SOURCE:
The tention is not holding the material in place slips around when im sewing .
Do you guide the material with your hands while sewing?
Jul 07, 2015 | Sewing Machines
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at www.sewing.about.com too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
Bobbin jaming up
Clean the bobbin area.
Thread the machine with the presser foot up - always,
Make sure the bobbin thread is feeding clockwise and through the guides on the bobbin case.
Lower the threaded needle down and back up while holding onto the thread end. This will pull the bobbin thread up. Hold onto both threads and pull under the presser foot and to the back of the sewing machine.
Hold on to the thread ends and lower the needle into the fabric, then press the foot pedal.
You may want to use a leader - a folded scrap of fabric that you sew to the edge of and then **** against the fabric you want to sew. Sew off the leader and onto the fabric and this will keep the thread from going down into the machine. You can have a few stitches between the two to make it easy to cut the leader away.
When you stop to adjust the fabric make sure the needle is down to anchor the fabric (turning corners, sewing a curve. etc).
The slightest movement of the fabric when the needle is up will sometimes cause a thread jam.
Mar 11, 2010 | Bernina Sewing Machines
I keep having my thread getting tangled around the bobbin i have re-threaded the bobbin triied all different ways and it still keeps doing this, its a brand new maachine and im really annoyed
This can happen if you stop to re-position the fabric and do not have the needle down into the fabric. This usually happens when you turn a corner or are making a curved seam.
Make sure to always thread the machine with the presser foot up - this is important.
Lower and raise the threaded needle, holding onto the thread tail and bring up the bobbin thread. Take both thread tails under the presser foot and to the back of the machine.
Keep the threads to the back of the machine when you begin to sew.
Mar 06, 2010 | Brother LS-2125 Mechanical Sewing Machine
Presser foot does not snap down - it rather floats
Hi, the presser foot bar needs cleaning and oiling. Open the cover over it if you can or just go at it from the bottom. It may be best to clean it with something with kerosene such as liquid Wrench from your local hardware store or a gun barrel cleaning solvent. Then a clear sewing machine oil and exercize it good until it starts snapping down again.
Rick
Nov 22, 2009 | PfaFF Sewing Machines
Lost the feet that holds the fabric down.
its called a foot or ski and you should be able to purchase them from any shop sewing shop. other shops may sell them too. simply ask a member of staff if they sell feet /skis for sewing machines.
Apr 08, 2009 | Singer 8280 Mechanical Sewing Machine
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Problem with the foot and feeder
You can also check the pressure foot regulator (near were the light is open the cover as if you were threading neelde and it is in there its mealat and has numbers 0-3 on it. 1 is for heavy fabrics, 2 for med, 3 is for light and 0 is for darning or fre motion sewing. the standard setting is 2. try both this and the feed daos, one of them should work.
michelle NH
Mar 23, 2008 | Simplicity Denim Star SW210
Simplicity Denim Star SW210 Logo
69 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Steve Allison
Steve Allison
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
