Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Self Cleaning filters are not cleaning themselves.
About every 6 months I end up taking the filters apart on the bottom of the dishwasher, cleaning them and putting them back. However they just end up clogging back up again. They are suppost to self clean. Any suggestions????
  • 901 Answers
Pl check the over-head tank of your premises. Clean the tank.
Alternatively you can install a master filter in a accessable level( height ) for the easy cleaning. There are no self cleaning systems. If the filter is removed it will go and clog the out-let valve and you will end up in more maintenance cost.
Posted on Apr 29, 2010
Filter doesn't self-clean
hello diane,
i would think that unless your model says it is self cleaning then yes it is normal to have to clean the filters on a dish washer. the amount of time between cleans would depend on how dirty your dishes are.
Apr 20, 2013 | Kenmore 24 in. 15932 Built-in Dishwasher
Should there be a little water left in the dishwasher
yeah there should be a bit but the bottom should also have dishwasher salt in there. this is the bottom. the salt helps kill smells also helps cleaning. when you bought the dishwasher it should of come with a funnel thats for filling the salt into the system.
Jun 08, 2017 | Frigidaire FGHD2433K 24 in Builtin...
HOW DO YOU CLEAN THE FILTER IN A MDBH979AWS3
This is a self cleaning dishwasher. This means the chopper inside the wash pump assembly crushes all the food waste and pushes it down the drain.
If you are having dirty dishes then the chopper is choked and needs cleaning.
You will have to open the dishwasher wash pump assembly to get there.
See this diagram for details. The chopper is item 6. I am assuming you have cleaned all the wash arms holes etc.
Mar 12, 2012 | Maytag Jetclean II MDBH945AWS Stainless...
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
Cleaning the filter on frigidaire ultraquiet dishwasher
Hello Friend,
I see that you are wondering how to clean the filter on your Frigidaire dishwasher, model# FDB1050REC. The inside of your dishwasher is self-cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth.
The filter is self-cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones, and pits. To remove this glass trap, grasp the handle, lift out, empty it and replace it. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
The top is not cleaning and the bottom is cleaning poorly
The most likely reason you are experiencing poor washing results with your dishwasher is because the filter on the pump is clogged. This tip i wrote will help ya to take apart the pump and clean that fliter, http://www1.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher does not drain after a cleaning cycle. the smelly water stays on the bottom of the washer.
Check the filters (triclean you have to remove the 2 screws on both upper and lower filters inside the machine). Remember how they came apart because you will have to reassemble them 8)
Check both ends of the flex tube from the dishwasher to the drain, and the drain port for blockages.
Nov 17, 2009 | GE Dishwashers
My kenmore 665.13719k600,wont clean the dishes
Try cleaning your dishwasher using a dishwasher cleaner. this will clean out the build up. There is one that i recommend and it is called Dishwasher Magic.
You can prevent this from occurring in the future by, installing a Water softener in you home. this will heel the build up.
Jun 19, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
LG LDF8812 Diswasher - Self Cleaning Filter not cleaning itself
you should not have to use any type of screwdriver to remove filter. The rest of it , leave alone. Take both rotors out and run unit. Both rotors top and bottom should push water through at a good rate. If not, a blockage in water /motor line. I suspect the rotors simply need to be properly cleaned, If not rotating properly it will cause undesolved residue.
Mar 28, 2009 | LG LDF8812 Stainless Steel Built-in...
Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Dec 22, 2008 | Maytag Dishwashers
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
519 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
