Question about Maytag MAH6700AWW Neptune Front-Load Washer
Stays on for about 10 seconds then shuts off - Maytag MAH6700AWW Neptune Front-Load Washer
  • 26 Answers
It sounds like a machine control... Check the board by the timer for burned components. While in there take a look for the tech. sheet. This is often in under the top, or by the timer in the Maytags. The Neptune tech sheets are pretty helpful when diagnosing issues.
Posted on Apr 29, 2010
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
Stays on for 5 seconds then shuts off latitude E4300
Start by cleaning the fan and vents, if you haven't already. Reseat the memory mods. Have you done any updates or upgrades? Can you do a system restore/recovery? Will it boot to safe mode?
Jan 10, 2013 | Dell Latitude E4300 PC Notebook
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Dryer won't stay running. It will start, run 10-15 seconds, then shut off. I can restart it immediately but get the same results.
i would check the door switch. it may be worn just enough that the vibration of the dryer opens the circuit for just a moment. then check for other loose connections. the fact that you can restart immediately usually indicates a momentary break in the circuit. a temperature switch usually takes a short time to reset. while it's still running, try rattling various switches or smack the door to see if it shuts off. (just a couple of simple ideas to start with).
good luck....jay
May 21, 2009 | Maytag Dryers
Tv will not power up, shuts off after 10 second
http://serviceman.site88.net/index_files/MitsubishiTV.htm
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
