Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Pool heater is not turning on. theres power going in but not torning on
  • bob sieger Dec 31, 2011
    service indicator light on and operation stopped.. what is needed to resume operation
  • 64 Answers
Are you getting any error codes? What is displayed on the heaters control panel? Age and model of the heater?
Posted on May 18, 2010
Rheem pool heater there's no power to the display
ensure proper supply voltage to the heater....either 12 or 240 vac. display screen should get 24 vac.....if screen is supplied 24 vac then replace the display screen board.....if not getting 24 vac problem is occuring before display screen
Sep 13, 2013 | Pool & Spa
I have a sta rite heater when pool turns on the heater lights go on threw its cycle but when i go to turn on its like there is no power
does the blower come on? if not, make sure you have the proper voltage plug installed. or the voltage plug may be loose
Aug 23, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Getting black debris from heater
check gas pressure possible overheating if ok check to see if filter has ripped or torn elements
Apr 18, 2013 | Jandy Laars Hi - E2 350,000 Btu Heater
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite Maxe therm heater turns on by itself
These pool heaters have a very helpful and easy to follow chart in their users manual for problems such as this one. There are questions that you will need to answer that you cant answer unless you are looking at the heater. Below is a pdf version of the manual.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Apr 01, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
I have power to the unit. Thats checked. When
You will need to replace the board before you can start. If that dosen't fix it, it will give you a reading as to what is wrong. PS make sure the power switch is on, most were on the front but some were about half way down the right side of the unit. They moved it to the face of the unit because it was too easy to overlook on the side.
Sep 30, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have power going to control panel of heater. I
raise t temp if problem continues change t board
Sep 01, 2009 | Pentair Minimax NT Heater
I need to run the filter pump without power to the heater
dont worry about the heater it will not come on so turn the pump on before it turn green call a pool guy
Aug 17, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
The sta-rite maxitherm heater I am asking about is for an inground pool
I would like you to try a reset of the system. Turn off the power on the heater, then turn off the circuit breaker that goes with the heater. Wait about 20 minutes and then try and start the heater. If it still will not power up, turn the display panel over, there are diagnostic lights on the back side. If the light is on next to the AFS, that is the Air Flow Switch.
Jun 20, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Millivolt pool heater will not ignite
Most heaters do not require power for the pilot to remain lit. Is there power at he unit? If it worked yesterday and not today has anyone turned it off at the circuit breaker? If you have power turn the gas valve off for 10 minuets and then relight to see if it needed a reset.
May 23, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
109 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
