Question about Maytag Washing Machines
The washer tub isnt spinning- - Maytag Washing Machines
  • 20 Answers
If it is a top load then my first guess is that the lid switch is broken.
Posted on Apr 29, 2010
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Jul 18, 2011 | Maytag Washing Machines
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
My washer isnt spinning the clothes out
First check the belt for wear and the pump for bearing stiffness. If all of that is good then the Main pulley's thrust bearing may be worn out (not releasing the tub). The kit has a new pulley and assorted goody's to restore the action on the brake cam release. The trick is to add the correct amount of washers to allow the brake to release but keep the tub locked down for wash mode.
HOW TO PICTORIAL and more HERE
Feb 28, 2011 | Admiral Washing Machines
Portable washer is getting water but the tub isnt filling up
Sorry to tell you this but this machine probably has a hole in the tub (the plastic part). The basket (the part you refer to) is fine, but to replace the tub, it isn't economical. You will probably have to get another machine.
Joe
Sep 02, 2009 | Kenmore Washing Machines
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer 90 series wont spin
If your trans and coupler are good then I would suspect the drive block or spin tube. You will have to remove the trans to change out the spin tube. Take out the basket, there should be 2 ears from the spin tube that nest in the drive block. Attached is a photo to help you understand. Before all this make sure nothing is caught between the basket and the tub. Catriverd8086fb.jpg
Nov 26, 2007 | Washing Machines
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
