Would not spin. E20 flashed
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
SOURCE: E20 error message
The E20 error code means - not draining It seems more as an issue of a clogged drain line or malfunction pump.
SOURCE: code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
SOURCE: Water won't drain, error message: E20
error code E20 means that the coin trap/drain pump hose needs cleaned out.It can be done by the owner with a friend helping.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.Or you can lay the unit on its back side.
3. Now that the unit is propped up look inside the hole on the bottom of the unit - on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Of course, if your washer is setting on top a drawer/pedestal then you will need to take out the screws that connect the two and then you can lay the washer down on its back onto the pedestal
SOURCE: E20 Error Code
Greetings jeanne1568,
Other consumers have reported this error message and found it relates to your "Coin trap assembly" being blocked, therefore not allowing all the water to pump out. The suggestion out there is to remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
I hope this helps.
Dorothy
Go Ahead. Use Us.
SOURCE: E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
