Question about Asrock P4i65GV Motherboard
I have got the P4i65GV motherboard its not geting any powersupply so i tried another SMPS with 24 pin on that and it did not work ..but when I cinnect the SMPS fan just rotate for while and stops?? is the mobo faulty or SMSP???
  • 4,737 Answers
Before you start troubleshooting with the motherboard, better you try with another SMPS and make sure you connect the four pin power supply cable onto the motherboard I have got the P4i65GV motherboard its not geting - p4i65gv(enlarge).jpg It's located just behind the game port of your motherboard, white in color with four female connectors. If power supply isn't the problem, you need to check the motherboard by resitting all the ad on cards like CPU/RAM etc... Good luck and do let me know if the problem still persists...
Posted on Apr 29, 2010
Can i use 20pin atx powersupply instead of 24pin, is it compatible to ep-5ela-3i
The 20pin PSU is for use with normal AMD (Athlon XP, Duron, and athlon64) or Intel (p3 and P4) based Motherboards, but the 24 pin ones are specifically for the Intel Xeon chips (used in servers).
Therefore a 20pin PSU connector will NOT work in the 24 pin connection slot.
I suggest you buy a adapter.
You can buy it from:
http://www.amazon.com/StarTech-com-6-Inch-Motherboard-Adapter-ATX2024MF/dp/B0002GRTZQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1308495882&sr=1-1
Please rate my solution !
Jun 19, 2011 | EPoX EP-5ELA3I Motherboard
I have Sony VGC-RB30 and after power failure it is don't start at all, I can heat clicking and green button at back is flicking, what should I do?
first you have to remove the 24 pin conncter to your motherboard from the smps and short the green and black pin and see wether the smps is working if not working change them if working remove the the four pin conector to the motherboard from the smps and switch on the computer if the processor fan is working connect back the 4 pin connector to your motherboard and switch on the computer if not working the power section in the mother board has failure you can get assistance from a chiplevel service personal
Mar 27, 2011 | Sony VAIO® VGC-RC310G PC Desktop
No connexion with the screen screen is black
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 27, 2011 | ASUS Computers & Internet
No keyboard, no display, doesnt sound like computer boot ups
firs remove the cover and remove the 24 pin conected to the motherboard from the smps you will also see another 4pin conector conected to your motherboard from the smps remove them to then short the pin green and bleck in the 24 pin connector and see wether the smps fan is working if working coneect the 24 pin to the motherboard leave the 4 pin aside and switch on the computer if the processor fan is working switch of the computer and connect the four pin conector to the motherboard and switch on the computer if the processor fan is not working then you have problem with the motherboard
Jan 29, 2011 | HP Computers & Internet
My computer want come on with the power the light is on on the back of the tower but it will not come on when i push the power button
you need to check the SMPS first remove the 24 pin conectior to the motherboard from the smps and short the green and black pin if the SMPS fan is working there is no problem in the SMPS conect tthe 24 pin conector to the motherboard then remove the 4pin conector from the motherboard from the smps and switch on the computer of the computer fan is working you have froblem with *********** board
Jan 17, 2011 | HP 1GHz Compaq/ Desktop Computer (RB1GPKG)
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
I have itel 845glly. motherboard
You must use a 24-pin power connection. Change your power supply and you should be able to make the connection without further issues.
C2Solutions
Aug 05, 2009 | Intel D845GLLY Motherboard
Asrock P4i65GV Motherboard Logo
90 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
