Remote control got wet, can I still use it if I let it dry out
Remote control got wet, I dried it off as best I could. Removed the batteries and wiped the are clean. I put batteries back in but the remote isn't working. Can I still use it if I let it dry out completely?
zeusfaber
  • 247 Answers
SOURCE: drying cycle - laundry comes out wet!
Try Tresilla's advice to check the filter first. If you draw a blank there, and if your machine has a separate condenser (as I suspect it will have) then you might want to check whether the bottom end of the condenser, the condensate drain hose which runs from the lower end of the condenser down to the drain pump, or any vent hose (these are sometimes connected to the bottom of the condenser too) has become choked with lint. (So you know what to look for: The condenser is likely to be a largish (often plastic and flattened) duct which runs from the back of the drum up to the dryer blower at the top of the machine. Connected about a third of the way from the top, it will have an inlet hose which leads to the cold water inlet valve and somewhere towards the bottom, a fatter drain hose which leads down to the pump. There may also be a vent hose coming off the very bottom, leading to a point near the very top of the machine). A.
Posted on Mar 21, 2007
gungraveisli
  • 75 Answers
SOURCE: wet ps3 controller
that all depends on how wet the controller was. if anything inside got too wet then most likely no. however, if the outer casing was all that was afflicted then yes. the controller should have no problems. hope this helps.
Posted on Mar 16, 2009
netrakid250
  • 52 Answers
SOURCE: wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
Posted on May 31, 2009
ginko
  • 19396 Answers
SOURCE: my phone fell into a cup of water
If water penetrated inside the LCD display , then the display must be replaced. Moreover, the liquid may have shorted some component , and in that case there is more repair job to be done.
All you can do is removing external covers if possible, and drying the phone a little longer If the phone does not come up after one week, then repair or replace it.
Posted on Jun 01, 2009
micromatikal
  • 2777 Answers
SOURCE: batteries leaked, cleaned as best I could, but
If you have had a battery leak then this is a very bad thing. It's possible that the battery acid could have corrupted the system board in the remote. I would call Sony to see if they have any suggestions for you, however I think you may end up needing to replace the remote.
Posted on Jul 13, 2009
MY SMART TV REMOTE CONTROL GOT VERY WET, ITS NOT WORKING NOW WHAT CAN I DO?
Remove the batteries and place the controller in a bag of dry rice for about 48 hours. Then look inside where possible to see if it looks all dried out. If so, replace batteries and try it then.
Dec 09, 2014 | LG Magic Motion Remote Control With...
What to do if my remote gets wet
If it got wet with fresh water, take the batteries out, dry what you can with a clean towel, and let it and the batteries dry thoroughly. Put it in a sunlit window for a day or two. Better yet, put it in a bag of uncooked rice.
If it was salt water or something else (juice, coffee, etc) then it's tougher. Again, remove the batteries, dry what you can, clean what you can with fresh water, then dry everything and cross your fingers.
Nov 09, 2014 | Philips Televison & Video
Sagem remote control got wet and wont work
Try putting the remote in a bag of rice covering it completely, the rice should dry it. You may need to open the remote and wipe or clean the contact points.
Aug 02, 2014 | Televison & Video
Remote got wet
take the batteries dry them then dry the the remote then let it sit (somewhere sunny) for 5-10 minutes put the batteries back in (or buy new ones) I'm sorry if this does not work.
Jun 01, 2013 | DISH Network Televison & Video
Garage door opener remote got wet
Take it apart, removed the battery and let it completely dry. Install battery and reassemble and it should work.
May 24, 2013 | Chamberlain Televison & Video
Mx980 got wet
USE A BLOW DRYER AND DRY COMPLETELY.. OR LET IT SET FOR A FEW DAYS WITHOUT THE BATTERY... AFTER GETTING WET IF YOU DON'T REMOVE THE BATTERY IMMEDIATELY THEY COULD GO BAD.
Mar 15, 2012 | Universal Remote Control MX980 LCD Remote...
Remote Control got wet and quit working can it be fixed or is there a replacement that has all the proper functions? TV Model #TLX-04240B Polaroid S/N JR7G4186730007543 Remote Numbers 66700ABA2-012-R ...
Since the remote got wet, remove the batteries and let dry or you can try to open it and use a hair drier to dry it.
If that after drying it still doesn't work, check this link to find a new remote control.
Oct 30, 2010 | Polaroid 4241-TLXB 42 in. LCD Television
How to fix a Sony Tv RM-YD026 remote after getting milk in the buttons
take batterys out then take out the little screws in battery compartment pry open the two halfs clean the board and buttons and let dry dont wipe the carbon off it is the main part of the switch for the buttons just clean with water and let dry
Oct 20, 2009 | Sony RM-YD023 Remote Control
My Panasonic Lumix DMC-TZ3 was soaked in water. It isn't working, will it work when it drys out?
It depends on how wet it was, if the entire thing was submerged, or even a large portion, it probably will not.it may turn on but it is likely that the lens will be damaged permanently. However if it was just wet upon the outside, like it was used out side during a rain fall, and then wiped dry every thing should be fine.It all depends,try drying it out thoroughly, letting it sit out with all lens caps and lens attachments removed, battery doorway open. is the best thing you can do. I hope that everything works out for you. God bless...
Aug 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My remote start is going off on its own, what
the control box got wet take it out and dry it. dry with a blower drier make it dry good then put it back.
Jul 24, 2009 | 2000 Nissan Pathfinder
Televison & Video Logo
490 people viewed this question
Top Televison & Video Experts
Electro Med Services...
