Question about Sony Handycam DCR-DVD101 DVD Camcorder
Viewfinder screen and viewfinder are black and lens is off
    Problem Solver:
  • 9 Answers
Make sure the selector switch is turned to record (the center position) and camcorder is turned on. Make sure the viewfinder is pulled out fully when you look in it. If that doesn't work try resetting the camcorder. Open the LCD and there is a small hole near the play button, gently push a paper clip in the hole all the way and press the power on button.
Posted on Apr 13, 2008
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
The screen of the viewfinder has a black dot.. i tried to clean it but it cant be removed,..how can i removed it?
Remove the lens of your camera, do it in a clean room, look at the mirror insie the lens to see if the dot is not there rather that on the outside of your viewfinder.
If it is not there it might be on the inside part of the focusing screen. Still inside the camera look at the upper part of the body, the focusing screen looks opaque.
If you still cant find the dot it might be on the inner side of the focusing screen.
Here is a tutorial on how to remove it on a d70 it is essentially the same thing on your camera.
Otherwise it can also be on the inner part of the viewfinder. In this case I recommend to send the camera to a repair shop as the removing of the viewfinder seems to be more difficult on the d3000 than on other camera.
Hope this helps.
May 30, 2011 | Nikon D3000 10.2 Megapixels SLR Digital...
My Canon EOS Rebel T2i EF-S 18-55 IS Kit 18MP Digital SLR 4462B003 USA Model will not come on. What is the possible problem?
It's probably coming on but the button has been pushed to activate the viewfinder so all information gose there and the LCD screen remains black OR because this camera has an interesting feature just under the viewfinder that scenes the photographer looking into the viewfinder automatically shuts off the rear LCD screen. If this sensor is blacked then the LCD screen will not come on.
May 12, 2011 | Canon EOS 550D EOS REBEL T2i Digital...
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
Black screen on my s6500 fd
I assume you removed the lens cap...;-)
If both the viewfinder and the screen is black, it is most likely an error on the CCD. If the viewfinder is OK, but the screen is dead, the problem is probably the LCD.
Hopefully you still have warranty on the camera?
Oct 02, 2009 | Fujitsu Cameras
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
My Canon 300D SLR will turn on, and led display comes up saying battery is full and yet when you go to take a photo you cant see anything but black through the lens.
Obvious Questions, but you didn't supply the information.....:
1. Is the lens cap off?
2. Are you looking through the viewfinder? You will *NOT* be able to use the LCD screen as a viewfinder.
Otherwise, there is always a light path through the lens to the viewfinder, so....
1. Have you tried a different lens?
2. Have you checked the mirror is down?
May 26, 2008 | Canon Cameras
Black viewfinder and screen
Most likely it is a mechanical failure such that the reflection mirror does not return back to its normal position, then blocking any light to the viewfinder.
Check this by unmounting the lens. If so, you may have to consider a repair operation.
Feb 08, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Sony Handycam DCR-DVD101 DVD Camcorder Logo
123 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
