Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
After changing hi limits,fan ***.,ignition control,and fusible link.the heater will still not start?
  • 33 Answers
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
Why do I FIND VOLTAGE ON L2 and F2 and none on L1 and F1
one of them is hot all the time check the safety circuit make sure voltage on both sides of pressure switch, fusible link and hi temp limits if not something is open
Oct 16, 2014 | Pool & Spa
Pilot stays lite but burner won't ignite
you have either an open safety, poor wiring connection, or problem with tstat controls
Apr 15, 2014 | Zodiac Jandy Legacy LRZ 175K Commercial...
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hi limit reset
check to see if fusible link is good then check hi limits they are by the plumbing inlets
Nov 09, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do u remove hi limit switch from a Jandy LX 400N-L heater model#LX400N-L
high limits are located at header where pipes go in underneath
if those are ok check fusible link maybe 2 one at bottom one at top under top cover
Aug 15, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have 2 hvac units running an electric heating element for the heater. Both limit controls are set the same. One is ignited the flames and continuing with flames for close to 3 min. The other is taking...
Hi, these Honeywell combination fan/limit controls are used for turning the fan on after the combustion changer reaches the factory setting on the round dial that you see when you remove the cover. The high limit will turn the fan on when it reaches this temperature, and off when the stat is satisfied. If the blower motor fails due to a burn out or short, it shuts the main burners down on the high limit setting. These controls can be removed and you can clean the probe which has a set of contacts at the end. Sometimes this will fix the problem. Check the settings on the dial to see if they are set right to come on, the time it takes between cycles, and the temperature they are set to shut off. This sounds as though you need to check your thermostats also. They could be a problem. You say electric heat, but then you are saying flames? If these limits have the manual fan button, make sure they are on auto. Long delays could also mean you have a dirty flame sensor located by the pilot. You can clean the metal tip with steel wool or fine sanding cloth. Short heating cycles may be your thermostats like I said before. You shouldn't have to replace the fan/limits as I told you what they control. These will cause a fan to run and not shut off after the stat is done, so check to see if they are dirty. Please keep me posted.
Shastalaker7
A/C, & Heating Contractor
Feb 12, 2011 | Honeywell L4064B2236 Fan/Limit Control...
This heater sits for a year without use and now I can not turn it on. Does it have multi-button reset to turn it on again?
These types of plug in portable 1500 watt or less heaters use fusible links, limits, safetys etc some of which dont auto reset, many times failing due to one of these essentially non servicable components,I have several times taken these various defective heaters apart, rarely unless an older better built unit, have I seen fan motors fail, nor heat strips, 90% are some safetys/limit, the rest are the switch. unles you can bang or tap it to come on its through. I myself hack the heaters bypassing the failed part, often running them direct , no limit, fusible link or even switch, only to use them in situations where I wont sleep or leave the area, as there is zero safetys now! i do not recommend this to anyone except a technician, i have several motors and coils hanging by the cords running sans their plastic housings a naked heater, they work for years this way so clearly the limits/safetys are the weak pots on these units, by design I suspect.
Dec 16, 2010 | Honeywell HZ365 Ceramic Compact Heater
Heater fan not working in a 1996 Chevy S-10
I looked at wiring diagrams at bbbindustries: the orange wire to the 20 amp htr fuse is direct from the ignition switch. You might check: that orange wire splices to the 10 amp brake fuse (fuse #12). check if that also has any voltage problems.
There are two black fusible links that supply power to the ignition switch. the fusible links come from the battery junction block.
May 26, 2017 | 1996 Chevrolet S-10 Pickup
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
101 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
