Question about Dishwashers
Maytag dish washer
Thanks for your reply. like i said started trying to clean the sprayers now i'm in trouble. thanks don
    Genius:
  • 3,587 Answers
Sounds like a real issue...is it the case that you can't get it back
Posted on Mar 24, 2008
Having trouble with dishwasher- I feel like dishes are not getting clean- will replacing circuit board on dishwasher help dishing become cleaner?
You may need to clean out the filters that keep food from being pumped up to spray out of the sprayers. This will depend on your make and model as to how to do this. Clogged filters will reduce the amount of water being sprayed. Try opening the door mid cycle to see if there is a vigorous spraying action. If the water being sprayed is underwhelming, it may be clogged filters.
Feb 13, 2013 | Maytag Dishwashers
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
The water supply arm for middle sprayer is not held in place by clip that is attached to bottom of dish rack. Does not meet up with water outlet on back of washer and also impedes movement of sprayer arm....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | KitchenAid KUDS40CVSS Builtin Dishwasher
I don't beleive my sprayer arm is working on the bottom of DW
The problem is hard water and your softener must not be taken it all out. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 05, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
The water does not spray inside, it does fill but does not spray thus the bottom sprayer does not move
check your rubber seals to sprayer from back wall of dish washer. if ripped or dried out need to replace them.
Jan 24, 2010 | Maytag MDB9750AWS Built-in Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher
Are the sprayers unimpeded? Have you checked for any debris in the bottom of the washer? Are you using the proper amount of detergent which means enough for 2 washes. . Hope some of this helps.
Jul 17, 2008 | Frigidaire ATF6000ES Front Load Washer
I have a maytag mdb4000aww dish washer. The dishes aren't getting consistently clean. I wanted to clean the trap/filter. There's two ports towards the front side. The one on the right i was able to...
Hi
The port on the left is the float it has no filter don’t try to remove it. To get your dishes cleaner: step one, each time you wash run the tap water in your sink till it’s hot. Step two, buy what’s called “dishwasher magic” use that every 2-3 months. Three, use rinse aid. Four, check the sprayer arms, make sure all the holes are clear and that they spin freely when the dishwasher is loaded. There is the possibility that the interior motor area needs to be cleaned, if you’re handy you can remove the lower spray arm and the cover, lift that up to expose the interior motor area, this is fairly involved, if you’re not comfortable you should call for repair, it shouldn’t cost too much.
Apr 01, 2008 | Dishwashers
Soap stuck in dispenser/dishes not getting clean
try and find a manual to assist you, pdfoo.com , but most ot the sprayers have clips that hold them on/in. just be carefull not to break any.
Jan 21, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
