Question about Car Audio & Video
I have 2 amplifers 3 capitcators and a crossover and and three batteries. My ground and my remote wire some how touch on my amplifer that was hooked up to my subwoofers. But it still played. Now when i cut my vechile off and started it either one of my amps would come on. I have two new amplifiers and neither one will come on does the ground and the remote wire need to be replaced or what.
    Problem Solver:
  • 10 Answers
Yes they need to be replaced
Posted on Apr 29, 2010
2002pathfinder fan control amplifer blows out after working 15 minutes
Control modules are very sensitive to poor grounds, it causes the current to ground through compnents and damage them. Get a wiring diagram find the grounds and repair them first.
Jan 02, 2015 | Cars & Trucks
Subwoofers causing amp to go into protection mode?
This can be speaker wires touching, poorly grounded amplifier, battery power is too little for amplifer or speakers wired below minimum amplifer impedance.
Sep 20, 2013 | Car Audio & Video
How to connect an boss amplifier
Assuming you have an aftermarket radio. You must remove the radio so you can attache your RCA cables and the remote turn on. Run these down one side of the vehicle back to the amplifier. Run the power wire from the battery back down the other side of the vehicle to the amplifer (remember to place your fuse within 12 inches from the battery connection. You will need to find a grounding point. I recommend removing one of the side carpeted panels to do this. You will be able to find the frame. Make sure to sand around where you will be connecting the ground. Hook wires to the amp (RCA to correct color RCA wire inputs, Ground wire to (-), power wire to (+), and remote wire to it's screw terminal. The other end of the amplifier should have the speaker outputs for your subwoofer(s). Hope this helps. If you need more information visit www.mobileinformationlabs.com
Aug 28, 2011 | Boss Car Audio & Video
I have an eq tis performance teknique icbn/-5eq 5.1 channel pre-amplifer, i need help to how to connect to the stereo
Your amp needs to be connected to your stereo via rca to the rca jacks in the back of the stereo then connect the remote wire to the remote wire in the back of your stereo it should be blue with a remote flag on it. after that you need to ground the amp and run a wire to the positive terminal on the battery. make sure you install a fuse on the wire in between the battery and the amp.
Jan 29, 2011 | Car Audio & Video
How do i wire up my amplifer into my car
cable to battery, cable to ground(in the trunk somewhere. rca cables and remote wire from the back of the car stereo.
Aug 04, 2010 | Legacy 2CH 1000W AMP Car Audio Amplifier
The radio and the cd turns on but no sound comes out after having the battery replaced. The vehicle is a 05 Mercury Mariner
radio runs off two power wires, one full time power and one switched power check to see which is working. turn the key to acc. and see if power stays on with car off, check all fuses. open the hood and look at battery cables, look to see if everything was hooked up right and if there is a amplifer in your car could be a fuse on the line to the amp either next to the battery or next to the amplifer.
Feb 15, 2010 | 2005 Mercury Mariner
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Sony Home Stereo Fuse
When the wires touched, the output transistors overloaded before the fuse had a chance to blow. The outputs need to be changed. It is possible that the driver stage for the final outputs is bad also, but there is no way to know that without removing the bad outputs. Figure on $25-$45 in parts for this repair.
Dan
Aug 26, 2008 | Audio Players & Recorders
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
PLEASE HELP with PYLE PLUS GXA-280A
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Sep 24, 2007 | Pyle PLA985R Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
