Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
The "empty" light is for the cleaning solution. It needs to be replaced with a new clean cartridge. There should be a big button on the back of the cleaning unit which opens it up and allows you to replace the cartridge.
Hey there Guest! You were right about using the wrong controller. I WON a PS3 from work (awesome!!!) and it came with 2 controllers... been searching on the internet now for over an hour for a solution.. lo and behold I read your answer and switched controllers .. BLAMO! It is now loading Grand Turrismo 5 for me!!!!! TYVM!!!!! You ROCK!
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
