Question about Amana LGA90 Dryer
Smell gas dryer will not heat propane tank was empty just filled today
  • 33 Answers
You have an air pocket in there. Shut off gas unhook it then turn on dryer for a min then hook all back up should work fine. Hope this helps
Posted on Apr 29, 2010
Testimonial: "Thank you! Worked perfectly!"
Does a propane tank for a gas grill normally make a noise when almost empty?
Not always, but have noticed some regulators do this with out any other problem.
Jan 16, 2016 | Nexgrill 720-0234 (LP)
Smell of propane
call the company back explain to them about the smell and where you smell it and would like another test of the lines and appliances that are hooked up as to your medical seek a doctor
Apr 19, 2017 | Heating & Cooling
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Kenmore Elite He3 dryer that runs on propane. The dryer worked fine until i ran the propane tank empty. When I filled the tank the dryer worked but did not heat up. I bleed the propane line...
To check the igniter ya need to use multimeter set to ac voltage and check for 120 vac coming into the igniter if ya have 120 volts ac and the igniter does not glow the igniter is the problem. This tip i wrote covers what to check when a gas dryer does not heat
http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 24, 2011 | Dryers
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
2002 ford taurus
no theres not a valve for smells, it usually means that when your tank is empty, it smells bad because most likely your running on water and gas, which causes a bad smell, a good way to fix it, is to pour a bottle of a subtence called HEAT, thats what it says on the bottle, then just pour all of it in your gas tank and what it does is make all the water that may be in your gas tank dissapear.. hope this helps...and if it doesn't that usually means that you should replace your fuel fillter.
Oct 23, 2008 | 2002 Ford Taurus
My oven isn't warming up
can you verify the ignitor is working (ie: can you hear it sparking)?
1. If no, and you are absolutely sure there is not a buildup of propane inside the oven (or house for that matter), you can try lighting it with a match. If that works, you need to replace/reposition your ignitor.
2. If yes, do you smell propane after trying to light the oven?
A. If yes, STOP and get it fixed..
B. If no,
1. Check to see that your propane tank isn't empty?
2. Verify the regulator supplying the oven with propane is actually sending gas to the over (might need a repairman for this)
Dec 22, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Dryers Logo
75 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
