Question about ASUS Eee PC 900 Notebook
Faulty 900_LVDS_cable for my 900 screen
Need a replacement cable above. where can I source this?
  • 185 Answers
Last time I checked this guy had a few of them give it a try
http://stores.ebay.com/PAPPYS-PARTS-AND-CLEARANCE-SHED
Posted on Apr 29, 2010
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Olevia 232 t12 lvds cable
It might be best to replace the LVDS cable along with T'Con.
Jul 09, 2013 | Televison & Video
Green line tv screen
A defective or loose contacted LVDS cable can cause this problem. Re-seat the cable said above at it both ends and check. A defective T'Con board too can cause this. The LVDS is the flat cable the connects between display panel and T'Con board. If you wish see the cable and internal connections of LCD TV, check the link given below. Check the disassembey procedure to any LCD TV. Illustrations are there. Check the cable said above, which connects panel and T"Con board. This will be common to most models. Pull up older posts there. You can get an idea.
May 16, 2013 | LG 50PK550 50 HDTV Plasma TV
Any tricks to replacing the LVDS cable in Samsing LNS4051DX/XAA
Its easy but be sure the set is unplugged. The LVDS has little tabs that are on each side of the metal connection when you press in on the tabs the lvds cable slides right out of the Tcon and the other end does the same on the main board. To plug it back in press in the side tabs and then slide it squarely into the socket on the TCon and then release the pins when the connection is all the way in. 2_13_2013_1_58_03_pm.jpg
Feb 13, 2013 | Samsung LN-S4051D 40 in. LCD Television
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
How do I fix the problem of green horizontal lines being on my lap top screen?
This issue is appearing due to a bad LVDS cable or a LCD.go to your nearest service station get the faulty part replaced.
Mar 30, 2010 | Computers & Internet
Blinking red and green squares with blue fuzzy bars in the back
Before thinking of TV problem, you should play a DVD first and see how it goes. TV problem only happens when all sources were affected. If you have the same problem for all sources, open the cover, disconnect LVDS cable and re-connect it; then try to tap or shake gently the LVDS cable and see if the picture changes. If yes, replace LVDS cable. If not, then measure the power on supplies from main board to power supply board, see this 5 VDC is stable or not. If it works fine, the problem may come from T-con board or some case from defective panel.
Aug 17, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Gray screen
Try unhooking the LVDS cable from the controller board and see if it does the same thing. If so you need to replace the LCD panel.
Oct 27, 2008 | Samsung LN-R408D 40 in. LCD HDTV
ASUS Eee PC 900 Notebook Logo
123 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
