Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Cant connect to our network
Alright, for some reason i cant connect to our home network...ive uninstalled the drivers once and then connected it back to the computer and restarted the computer putting the drivers back on and got on the network for only three minutes...the network currently has no security settings. ive also tried connecting to the network through windows and through the netgear install disk...im running windows xp. any other things i might try? eveyone else in the house is able to get on the network. this is very frustrating and ive really run the gambit on things i can do...this apparently started after i installed spybot seek and destroy. well two or three days after at least.
  • 1,272 Answers
Hi, please perform the below task to configure settings on your computer:
1. Right click on My Computer icon and go to Manage. 2. Go to Services then go to Service and Applications. 3. Double click on Wireless Zero Configuration. 4. Change the Start Up Type to Automatic and click on Apply 5. Click on Start and press OK to close the window. 6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 7. Right-click on the wireless Network Connection icon and select 'Properties'. 8. Go to the 'Wireless Networks' tab . 9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 2. Right-click on the wireless Network Connection icon and select 'Properties'. 3. Click on the 'wireless network' tab. 4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK. 5. Right-click on the wireless Network Connection icon and select 'View Available Networks'. 6. Look for the SSID (aka Network Name) of the Wireless router or access point. 4. Highlight thee SSID from the list that you want to connect to. 5. Type the security Key here and click on the 'Connect' button. 6. You should have successfully established a wireless network connection.
Hope this allows you to resolve the issue.
Regards
Anand Gupta
Posted on May 03, 2010
I need help finding out why my computer says no burner connected when ive burned disc from my liteon driver before from windows and now when i go to burn it say connect burner when ive checked the...
sounds like a faulty electrical connection check all connections that attach PSU to your burner or go into administrative tools,computer management, device manager if yellow? uninstall or roll back then once you uninstall diconect from PSU then re attach re-install
Jul 27, 2010 | Lite On SOHR-5238S CD-RW Burner
The light on the back of my adapter is green, but i cant connect to my network. something to do with my IP address. i don't understand as ive had it over a year but now all of a sudden it won't work
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you dont know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 24, 2009 | Microsoft Wireless Network Adapter Xbox...
Won't connect to WiFi home network, keeps coming up with ünable to connect". My other laptop connects automatically
Go to device manager, network adapters, select your wifi adapter, right click then uninstall it. If you're with Vista, do not delete the drivers. Then when its gone, select action on device manager and scan for hardware changes. It will re install the wifi adapter back. Now try to reconnect back to your router, put in your security key and once connected, save it. When you boot it up again it should connect back automatically again.
Hope this helps.
Oct 02, 2009 | Lenovo IdeaPad S10e Netbook
One of two HP laptops connects to network but quit on Internet
did you play with your wireless router settings..?? When it is shown as unidentified, you have most probably set as hide network name . other computers may show up the name if you have saved the network settings on them at least once.
Drivers are fine as they are able to detect the network.
Sep 05, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Unable to access internet through router netgear ga311
Try to remove the adapter to the computer. Uninstall and reinstall the driver before installing the adapter to the computer.
Note. if you got the same problem as before download the latest driver of the adapter then try to reinstall the driver again.
Mar 24, 2009 | NetGear GA311 Network Adapter
Wont connect ti internet
Same device as mine. and im on home hub aswell. Uninstall the drivers. Restart windows. Reinstall the drivers. Hopefully this should make a differance. Also when reinstalling. make sure the device is not plugged in until you finish installing drivers. And maybe put it into another usb when you are ready to try again. this is something good to try on older systems. or OS's.
Oct 02, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
I had a home network set up between 2 Dell Dimensions computers Computer 1.) which as the broadband modem and Netgear Router on it "this computer is a windows xp". Computer 2.) with the Belkin...
Assuming you can't get it to run from the desktop icon, as long as the driver is installed which it should be, you don't need Belkin software to run your connection.
the easiest way in Vista is to go to control panel>network and sharing centre and see if network discovery is ticked green.
If not on top left of window is connect to a network, then see if your wireless connection is listed, if so click connect, if not at the bottom of the window, click set up a connection or network and follow the wizard.
Sep 10, 2008 | Belkin Computers & Internet
Zone-Alarm Problems
Uninstall ZoneAlarm, then reinstall. Unfortunately, turning it off won't fix the problem.
Jan 25, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Red light
Check that you have all the correct drivers installed, ie....for your ethernet. Look at the back of your pc at the yellow cable, if the light inside the connection isnt flashing, then your pc isnt recognizing your router and it most likely is a driver issue. Open the management console then device manager look for network adapters/controllers if you dont see any you dont have any and this is your problem. Install the correct drivers from your manufacturers web site and this should resolve the issue.
Dec 17, 2007 | Zoom X6 (5590) DSL Modem (55900003)
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
152 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
