Question about Aiwa AV-DV70 5.1 Channels Receiver
Audio just stopped working
The sound just stopped working. The speakers are hooked up correctly. No buttons were pushed on the remote.. One min it was working, and the next no sound...the speakers work when the FM radio station is on but not the TV or DVR.. Occasionally, in the middle of watching tv, the receiver would just shut off. we would have to reboot the whole system...Now we have no sound..
night71
  • 328 Answers
SOURCE: No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Posted on Nov 10, 2007
  • 4234 Answers
SOURCE: Speaker Problem
Before you replace the speaker, swap the left and right. If the sound problem follows the speaker, the speaker is bad. If the problem remains on the same side, the problem is with the unit. Lets assume that the problem is inside the unit. In that case, the problem could be just a bad connection. If you can solder, check the main board around the speaker terminals for poor solder connections. If that is not the problem, update this and I'll provide additional things you can test and check.
Dan
Posted on Mar 31, 2008
welcomejee
  • 10594 Answers
SOURCE: resseting the preset channels
Please download user manual of Aiwa XR-MN5 from here. This will help you to set new stations presets.
Posted on Oct 11, 2008
gopakumarg43
  • 74106 Answers
SOURCE: My Aiwa Colour TV, model No. TV-A2019, has
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Posted on Oct 15, 2010
MrJaHa5
  • 36 Answers
SOURCE: AIWA CX NA909 w/SXWNA 909 Speakers. Just hooked up for a friend that has been idle since a move 1 1/2 years ago. Can only get one FM station only. No AM at all...suggestions. Ralph
I guess you answered the question right then....., you need the antenna. If you've lost the antenna, I'd suggest a piece of wire, not too thick though...
As for the AM, that uses a loop antenna, so you might have difficulties with that one.
Posted on Oct 13, 2012
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
We have our subwoofer hooked up to our Denon AVR-787, but not getting any sound from it. I'm sure it's some knob we need to turn or button to push.... All other speakers are working Help?! We're not...
press setup/configuration on your remote you'll get configuration menu, then goto 'speaker configuration' check if the subwoofer is on, check that front speakers and others are set as small. There also could be subwoofer mode settings, remember current setting and try to change it.
Jan 08, 2011 | Denon AVR-787
I have a 32" flat screen and i have no sound.
hello. most likely someone pushed the mute button on the remote or went into the menu and into the audio area and turned off the speakers. So. begin by pushing the mute button on your remote and if that does not restore the sound. go into the menu and find the audio area and turn the speakers on.
Feb 28, 2010 | Televison & Video
Volume buttons stopped working
Check in the TV's AUDIO menu for anything related to turning on/off speakers. Also, unplug RCA's that you may have hooked up to the Audio OUT ports. Some video inputs may not have a sound input associated. The only one I can think of would be VGA, but even that would be rare.
Dec 05, 2009 | Samsung RS105N Remote Control
No sound from speakers
check to make sure you have your speakers turned "ON" many amps have "A" and "B" speakers or 1 and 2 and then check the back to make sure no wires are touching and determine what output you are using for your speakers.... also you have to make sure that that corresponding button is depressed for those speakers.... also check you have the correct input selceted for your speakers and that no wires are crossed..... theres is probably notihng wrong with the speakers you just need to paly with your amp
Jun 18, 2009 | Kenwood Audio Players & Recorders
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
All my speakers don't work.
Did you press the "TEST" button on the remote? It will send some white noise to each speaker that is hooked up, one at a time.
Nov 09, 2007 | Panasonic SA-HE100 Receiver
Speaker off
You will need an original Mitsubishi remote. The original remotes usually have 3 large oval buttons labeled Audio (up and down), Adjust (up and down) and Video (up and down). Pressing the Audio button will bring up the usual Bass, Treble, Balance... and Speakers Off. When you see those words press the Adjust button and the speakers will switch to On. Some sets have the Audio, Adjust and Video buttons behind a little door on the front of the set, so check there first and if not, get an original remote.
Dec 29, 2006 | Mitsubishi CS-27407 27" TV
Aiwa AV-DV70 5.1 Channels Receiver Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
