Question about Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model
We can't seem to keep the top bearing in the front spind.le from going bad. We have changed it several times but it gets destroyed after a few mowings
  • rdmcadams Apr 29, 2010
    We have put 2 new shafts in and have another on order. When the bearing is destroyed it scars the shaft. Should we check runout when the spindle is installed? If so were do we check it? What should the tolerance be? What should the tolerance be on the shaft alone?
    Mike
  • 10,865 Answers
Hello. Relevel your mowing deck as it appears that the weight is not balanced. Joe
Posted on Apr 29, 2010
  • 12,061 Answers
OK, the reason your bearings are failing, is because the shaft is out of "True" and also maybe the End Seals, are allowing crud and stuff to enter the bearing thus accelerate wear. But I am sure the most important thing is your bent shaft, it may only be a little out of "True" but thats all thats needed. Also it maybe Out of "Balance" as well, or instead of. Thats the area you must attend to. Also are you packing the bearings correctly with grease etc, before buttoning it all up? re any seals intact and in place.? Are you sure they are in right way round? Also they are the exact bearings you need? right? You are using a high quality bearing?
I have a 2002 dodgr ram 1500 2 wheel dr,how can I tell if my front wheel bearing is going bad?
Is it a one piece wheel hub bearing?
If it has 120,000 on it-- change both sides
The bearing & race type, you take apart & wash
off & look at for wear & markings & replace or
grease & return to service
If you hear a noise from 25 to 40 mph
On a rear drive car, you can remove the
brake rotor & feel the worn bearing --sometimes
You may be able to do that
I would just put the bearings on your Preventative
Maintenance list for 100,000 plus & change them
when you get there
Your Oxygen Sensors go at 100,000
Spark Plugs every 3 years & so on
I don't wait on failure,only as a learning tool,
then those items get added to my list
Sep 28, 2014 | Cars & Trucks
I have a 2001 Honda Accord with manual transmission. For the past couple of years I have an intermittent thumping sound. I may drive for months with nothing and then have it happen several times in a...
Steering Rack Mounting Bushings
Top Strut Bearing Plates
Stabilizer Bar Bushings
Sometime you have to actually take things
apart to find a problem,no one does that at
a repair shop just for the fun of it
That is what I have done for 49 years & have
problem finding any problems,just need to be
able to do all your own work,have lots of time,
& most important,patience
Sep 20, 2013 | Honda Accord Cars & Trucks
Lg washer wm2077cw had le error and did not work, blew in to tubing connecting tub to a sensor at top and now my reading went from 230 to 256. washer wont stop filling , leaks out front door. what is wrong...
When you blew into the tubing, you destroyed the water level sensor. You will need to change the water level sensor to stop the unit from over filling. That part number is 6601ER1006E. As for the LE error code, you one of 2 things go bad. Either the motor sensor has failed or the control board has failed. Chances are the motor sensor has failed and is the cheaper part to replace. The part number for that is 6501KW2002A
Good luck
Aug 03, 2011 | LG WM-2277HW Front Load Washer
I have a noise coming from what sounds like the 4x4 drive axle in front. I have change the gear oil and still have the noise. Any recomendations.
I would check the wheel bearing/hub assemblies as I have replaced several of these. Usually they make a thrumming, rumbling, or growling type of noise that increases with speed and which may get louder or quieter when taking sharper curves at highway speeds. I"ve seen very few problems with the front differentials on these but have put in dozens of hub & bearing assemblies that are noisy or worn. Sometimes, but not always, if you raise the front tires off of the floor a few inches you can rock the top of the tire in & out a bit which can indicate a loose/worn hub but they can also make noise without having any looseness present so it isn't a perfect test. You may need to have the vehicle put up on a hoist where it can be more closely inspected. I have seen some pinion bearings go bad on the front differentials but it is fairly rare. Good luck, hope this helps out a bit.
Jul 07, 2010 | 2002 Chevrolet Suburban 2500
Require front wheel bearing assembly for 1988 Plymouth Grand Voyager - LE 6cyl
very simple to change remove whichever tire is on the bad hub then remove the caliper and rotor then there is the axle nut remove this now on the backside there are 4 18mm bolts remove these four bolts then tap the bearing assembly with a hammer this may take a few smacks then go in reverse order to reassemble torque the axle nut to 110 ft pounds
May 03, 2010 | 1988 Plymouth Grand Voyager
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Clutch Whine on Toyota 4WD Pickup
Bad bearings. Perhaps a throw out bearing. The pressure on it varies depending on whether your pushing on the pedal or not, and how much. If the noise occured only when the truck is moving, then I would say it is the input bearing. Changed alot of those years ago.
Apr 06, 2009 | 1986 Toyota Pickup 4WD
Front spindles
ok... replace them....inspect the bearings and replace if necessary....
Robert
and have the cv joints inspected as well.
Sep 05, 2008 | 1991 Nissan Sentra 2 Door
Alero loud humming/roaring sound coming from front end.
That's indicative of a wheel bearing, which is why you were told to change that out. However, it's also possible that the carrier bearings in the differential (where the drive axles attach) have gone bad. That happened to me on my 300ZX several years ago, and I had to replace the diff bearings. I would have them checked out somewhere other than a dealer (you'll probably get a better price from an independent shop).
As a sidenote, to be sure it wasn't a wheel bearing, if you hear it quiet down in a turn one way but get louder in a turn the opposite way, it's likely the wheel bearing. If you turn left at speed and it gets louder, then it's the right bearing (since you're loading up that side of the car). If it gets quieter in a right turn, it's the right side (you're unloading that side of the car and not putting as much weight on it, so it doesn't drag as badly). See if you get that symptom just to be sure that the wrong side front wheel bearing wasn't changed.
Sep 01, 2008 | 2001 Oldsmobile Alero
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Logo
53 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
