Question about GE (PSS26MSRSS) Side by Side Refrigerator
Compressor runs 10 seconds then off about three to four minutes, does this continuously. Will not freeze or keep upper compartment cold.
    Guru:
  • 1,524 Answers
Try a compressor hard start kit.
Posted on Apr 30, 2010
  • GE Master
  • 43,501 Answers
Actually what you hear is the compressor trying to run but not actually starting and the overload kicking it off till the overload cools and then tries again...
Check out these tips...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 29, 2010
Compressor only stays running for about 10 seconds and kicks off. Will not turn on for about 3 minutes and continuously repeats this cycle.
Sounds like the compressor has siezed. Switch off to cool for 3 h.ours and try to restart. If it has a start capacitor, repace it
Jul 14, 2015 | Refrigerators
LRA2575T2 compressor runs for about out three minutes then cuts off after about three more minutes i can cycle the fan econ cool switch it will cool for three more minute any ideas
Possible blockage causing compressor to shut off, or compressor on it's way out. Check the fan is running full speed when the compressor starts
Aug 07, 2012 | Frigidaire Heating & Cooling
Goodman GSC130361DE premature shut off
im not sure what tstat you have? if you still have your tstat book it well tell you how to set it up. may be it was not programed when installed. i hope that helps
Apr 06, 2010 | Goodman CLQ30AR32 Air Conditioner
Relay keeps clicking on and off
We aren't sure either without putting a tester called an "Annie" on your compressor. Maytag has had a lot of compressor failures, and we have installed overload relays on some of these refrigerators, the compressors ran fine and pulled perfect amps, and hours later the compressors failed anyway. You can remove the overload relay from the compressor, and do a continuity check on the three terminals. You should get continuity between all three, and you should not get any continuity between any terminal and the compressor case or freon lines. If the compressor tests fine, then it is usually, not always, a bad overload relay. If the compressor tests bad, then your refer is not worth repair, usually a 900 to 1100.00 repair in my area in Seattle. You may still have a warrantee on it as most brands still have a full 5 year warrantee on the compressor. Good Luck, Appliance Specialists.
Jan 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Turn on the and it begins to cool for about 10
Possibly your compressor overload is bad. A cheap and easy to replace part mounted on top of the compressor.
Jun 05, 2009 | Heating & Cooling
Craftsman compressor runs for 10 sec. and shuts off.
I have a Craftsman 2hp/12 gallon Air compressor that does basicly the same thing, will start, run for about 3 seconds and stop. I replaced the pressure switch but still have the problem. Any suggestions?
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Side by side not cold
compressor overheated or stuck. also check starter relay...maybe broke.
if ever thing is alright,
let it stand for about 4 hours unplugged to cool the compressor.
plug it after 4 hours and if the compressor would still run for 10 seconds, then you have a faulty compressor.
tnx 4 using fixya,
drcool
Sep 09, 2008 | Kenmore Refrigerators
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Compressor won't stay on...
My guess is that you have a problem with one of the following:
Start relay...this gives a quick shot to the compressor to start the cycle...if it doesn't shut it will go to overload. The capacitor in the start circuit which assists the start relay or the compressor itself. Best bet: get a service guy in.
Dec 24, 2007 | Magic Chef CTB1521 Top Freezer...
Noisy compressor
If it's a buzzing for a few seconds followed by a click, your probably going to need a compressor. This sounds like that problem. Check your warranty. Many manufacturers went to 1 year on this in '06.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
142 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
