Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Refrigerator door water dispenser leaks
Frigidaire refrigerator door water dispenser leaks
fridgetech
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
Water is leaking from the dispenser area as well as the bottom of the freezer door of frigidaire frs20zrg
Hello Dc2464, thank you for your inquiry!
Based off the information you have provided water is leaking from the dispenser as well as the bottom of the freezer door. This is where your water line is located and it is possible that there could be a leak. I would recommend contacting a professional technician for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jan 14, 2016 | Frigidaire Refrigerators
Water dispenser leaks when pooring water
you have a broken water line.
needs to be replaced inside door.
Apr 03, 2014 | Frigidaire FRS26R4A Side by Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
The door water dispenser leaks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Dec 03, 2009 | Frigidaire FRS26H5AS Side by Side...
Water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side model:FRS26HF6BW2
Check the trap door where the ice drops through, it might be stuck in the open position, solenoid that operates the door may be bad.
Jan 27, 2009 | Frigidaire FRS26R4A Side by Side...
Water leaking from inside door
the water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Jan 21, 2009 | Frigidaire GLRT188WD Top Freezer...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
194 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
