Question about Texas Instruments TI-84 Plus Calculator
How do you change from base 10 to base 2 using a
How do you change from base 10 to base 2 using a TI-84 plus calculator
  • Texas Instru... Master
  • 8,064 Answers
Upgrade the calculator OS to the 2.53 MP version. It implements a lot of nifty capabilities among which you have fractions (mixed and improper) and log calculations in any base.
Posted on Jun 07, 2010
  • k24674 Jun 12, 2010
    OOPS:
    Sorry, I misread the question thinking you referred to logarithms. You
    will be well inspired to upgrade the OS anyway, but unfortunately it
    will not solve your conversion problem.
    To redeem my error I
    searched the ti website and got to the program archives and there is a
    propgram for base conversion. It is called BASECNV.83p. Do not forger
    to download the .txt companion file. You will find both files at this address:
    ftp://ftp.ti.com/pub/graph-ti/calc-apps/83/math/
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
There are no base conversion routines built-in on the TI-84. You can download various programs to do so from http://www.ticalc.org
Posted on Jun 04, 2010
Log 3 base 10
Press LOG 3 ENTER.
The LOG key on the keyboard gives you base-10 (common) logs while the LN key gives you base-e (natural) logs. If you want the log to another base you can use the logBASE function found in the catalog.
Apr 07, 2014 | Texas Instruments TI-84 Plus Calculator
Calculate the antilogarthm of 3.527
For this problem you have to type 10^3.527 or e^3.527. Of course it is important to know the base a of your logarithm for generally solution a^3.527 . See captured images
Feb 23, 2012 | Texas Instruments TI-84 Plus Calculator
Is it possible to change the faceplate of the TI-84 Plus calculator?
Yes, you can change the faceplate of the TI 84PLUS Silver Edition only, not the TI 84 Plus. Face plates are available for purchase at the TI online store.When you go the online store, select the country, then the calculator model. You will find them under accessories for the TI 84 Plus SE.
Aug 15, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
I got this in my TI-84 Plus: 32/ (6*10^23) = 5.333333E23 and i thought: 32/very large number= very small number. but my TI-84 plus says otherwise. How can i change this?
Double check: either you calculated 32 / ( 6 * 10^(-23) ) by accident, or the displayed result is in fact 5.333333E-23 (note the negative exponent). For example, 1E-3 is to be understood as 0,001.
Jan 09, 2011 | Texas Instruments TI-84 Plus Calculator
How to convert base 10 to base 2 and base 2 to base 16
The TI-84 has nothing built-in for base conversion. There are a variety of programs to do this available at http://www.ticalc.org
Jun 02, 2010 | Texas Instruments TI-84 Plus Calculator
Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
May 29, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-84 Plus gives answer as 2.145274703E14, what is E?
E is the calculators form of scientific notation. so 2.145274703E14
is really 2.145274703 x 10^14 or 214527470300000
Apr 08, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
437 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
