Question about Sony Cameras
I have a sony 8.1 cyber shot. Can I take a photo with higher resolution than 72 dpi? I can't figure out how to change the setting.
    Genius:
  • 1,040 Answers
In simple words select higher mega pixel value...
All the settings are not available in all shooting modes.
But in programmable mode find out settings viz."Image Size". By setting this at highest value You can get which you are looking for.
Posted on Apr 29, 2010
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
Change 72 dpi to 300 dpi
Your camera cannont shoot at either 72 dpi or 300 dpi. It shoots at whatever resolution you have it set for. Dpi (dots per inch) is a print specification, denoting how large (or small) your pictures are printed.
The DSC-W100's highest resolution is 3264x2448. Printed at 72 dpi, it can generate a print bigger than 40x30 inches, albeit a bit grainy. Printed at 300 dpi, you can generate 10x8 inch prints.
Again, dpi is a measure of how you print pictures. It has no bearing on how you capture images with your camera.
Mar 15, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Images taken by Sony DSC-W200 camera are only 72 DPI.
Pictures on a digital storage don't have any DPI. You get DPI when feeding the pictures into an output device, that is, you can put a ruler on it and measure it. Unfortunately JPG does have DPI tags. I don't know, what these tags try to tell us. With tag editors any value can be put into these tags without any visible effect. Non-displayed pictures are measured in Pixels (width x height).
Oct 19, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Photo resolution
Sony H1 takes photos at 72 dpi by default. But the picture quality will be good. if you want to convert it to 300dpi open the picture in adobe Photoshop and select image size and change resolution to 300 dpi. but the file size will be very high to up load. if you want to reduce the file size select the image size in adobe photoshop and reduce it according to your requirement. if my solution proves good please rate it. Regards.
Feb 04, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
I cannot figure out how to change the resolution
Upper left of the Arrow pad is the LCD Display On / Off button; beneath that is the Menu button; and further down is the Image Resolution / Erase button. You can change the resolution from there.
Dec 04, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Panasonic DMC-TZ3 72 dpi problem
Sounds like Photoshop's setting, or default setting, is to import picture at its maximum size. If you RESIZE pic on Photoshop, it shoud automatically increase DPI while reducing physical size.
The other thing to be aware, TZ3 defaults to a certain jpg compression. You can minimize compression of data with settings options on TZ3, but I doubt this has anything to do with your PhotoShop issue.
Also, in SIMPLE mode you can select a physical size for photo, even after pic is taken(resize), on camera.
Hopes this helps.
May 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Resolution
Many cameras will take pictures at only 72 dpi. Changing the resolution causes the camera to change the size of the picture in terms of pixel dimension (ie 800x600 vs 640x480) but always at 72 dots per inch. A photo editing program like Photoshop can change the resolution to whatever you need.
Dec 13, 2007 | Samsung Digimax 4010 Digital Camera
Confused about Resolution Sony DSC-T7
2.2 MB is the size of the file on your hard disk. Being a .jpg, it is a compressed file. The file size does not reflect the size of the image stored inside the .jpg. Yes, the size sounds about right. It will increase or decrease depending on how much detail there is in the picture. If, for instance, your picture is made up of nothing but uninterrupted blue sky, the disk file will be quite small - as the .jpg does not need to store much information (the more repetitive information, the smaller the file). On the other hand, if your photo consists entirely of nothing but blades of grass, the disk file will be comparatively large. When you see "DPI", that refers to print resolution. So, since you're not printing, but rather, viewing onscreen, Photoshop "assumes" a convenient "screen resolution", as though you printed on the screen (don't ask!). If you look at the other settings, you'll note that Photoshop also thinks your photo is 36" wide!!! You adjust the DPI (or photoshop will) when you print. Till then, it doesn't mean much. Let me give you an idea of your image's possible DPIs. Assume you really want to print a 36" photo: 2592/36" = 72 DPI If you make the picture 12" wide: 2592/12" = 216DPI At 10": 2592/10" = 259.2 DPI At 8" 2592/8" = 324 DPI How do you get my photos above 200 DPI? By printing the picture small enough, less than 12.96" on the wider side. See calculations above. The resolution at which you shot the image (2592X1944), will not cause blurriness. As for the cause? There could be any number. Was the subject moving? Were you? Did you shake the camera while shooting? Is your shutter speed too slow? Should you have been using flash? Is the camera autofocusing correctly? Are you waiting for the autofocus to lock before pushing the shutter the rest of the way? Etc. Hope this helps somewhat...
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Higher res pics on OPtio S4
This resolution doesn't matter to most software. It doesn't change the image at all, just occasionally the size it is displayed (only if the software scales the image according to the resolution, which most don't). This having been said, I doubt there is a way to change it in camera. But you could certainly change the XResolution and YResolution meta information with any good EXIF editor. Also, Photoshop can do this too, but it will mess up other things in the meta information. You should be able to script either to apply this change to a number of photos at once.
Aug 30, 2005 | Pentax Optio S4 Digital Camera
Cameras Logo
168 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
