How do I change the zoom 16:9 ratio on an rca d52w20 52 in rear projection tv with a universal remote?
  • zetan_anders Apr 29, 2010
    This problem happened before and I spoke with someone that directed me to type in something on the remote to change the format at the top of the home screen (picture format). What im saying is this problem is not in the manual.
    How do I do this? (switching between auto format and 16:9).
    Genius:
  • 1,043 Answers
Their are 2 ways that a Universal Remote can control your zoom. If it is the type of Universal Remote that you aim your remote at if to program the Universal, and it is capable of taking all of the functions of your original remote, then you could control the Zoom. The other way is if the Universal Remote was manufactured by RCA and they built in all of the functions for their TV's.
Unless you buy one of the higher end Universal Remotes, those that sell for between $150-800.00, most of then will only let you turn your TV on and off, and change the channel and volume. The manufacturers of the more expensive remotes program their remotes to give you full control over your TV.
The other choice you have is to order a replacement remote from RCA of the same type that came with your TV.
Posted on Apr 29, 2010
  • 19,396 Answers
Hi.
Go to Picture Menu > Advanced Picture Menu and set Autoformat and Film Mode On/Off. Also ensure that no PIP zoom is active.
Follow the instructions at page 34-37 of the manual here.
Regards.
  • 1 more comment
  • Ginko
    Ginko Apr 29, 2010
    You can reset picture format settings simply by disconnecting power cord.
    Also ensure that the TV is not set on the wrong input. There should be an input\source button on the remote.
    If possible test the TV disconnecting all cables apart antenna.
    If TV goes completely dark at random times, without changing settings, then the problem is the inverter board.
    Sometimes, when the problem is the inverter, you can see a faint picture by pointing an hand torch light near to the screen with a 45 degree angle.
    If the problem is picture format or settings, you should see the on-screen menu on the TV when you use volume or change channels. If there is noting, then it is the inverter.
  • Ginko
    Ginko Apr 29, 2010
    Hi, sorry. I posted on the wrong problem.
    My last comment was for a different TV from a different asker. Your TV does not even have the inverter, and the problem is just Picture format, not black screen.
    I will see what I can find on the specific model and keep you updated.
    Regards.
  • Ginko
    Ginko Apr 29, 2010
    As far as I know this TV, like most RCA diagonal projection, does not allow direct selection between 4:3 and 16:9.
    What you can change from remote is switching between auto format and 16:9. The same that you can do on menu.
    Try also disconnecting TV power cable for five minutes to reset the set.
    In the original remote there were the keys Zoom, Swap, and PIP controls to modify picture size. This commands are usually not available on universal remotes.
Picture larger than screen
I think you have overscan enabled.
I don't know anything about that specific TV, but that's the magic word you're looking for.
Jul 22, 2014 | RCA P52926 52" Rear Projection Television
I want to change picture like from full to zoom
just press the menu then go to picture settings then select aspect ratio to select 16:9 to have full screen in the picture.
Aug 28, 2012 | RCA P52929 52" Rear Projection Television
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
My tv the picture is bigger than the tv screen
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
Oct 20, 2008 | Akai PT4298HD Rear Projection Television
Zoom control
Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wrong aspect ratio!
It was the zoom !! I lost the tv remote, I went to Radio Shack for a Universal remote and they didn't have one with a Zoom button,
The tv menu doesn't have a Zoom button either...Finally found one that works and all is WELL! Depending on what the tv station transmits, the screen size changes in the auto-matic selection in the menu.
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
