Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Snowy Screen Good afternoon! I have Direct TV. I have had Direct TV for almost two years now and the picture was always not quite perfect. Recently, the picture just simply went out. Very, very snowy and you can even here that we don't have reception with a static noise. I have called Direct TV. They said that it was not them, that it is the TV. We have a HDTV TV but don't have a HDTV box for the satelite. They said all we have to do is lower the settings on the TV. Is this true? If, so can you help? One more thing. I don't have a control for the TV no more. If I need to purchase one to fix this, please tell me how. Thanks! Any help is appreciated!
    Scholar:
  • 170 Answers
Sounds to me like you using coax wire from your dtv. how about trying s-video and audio cables. if using coax, then your prob using the push on wire that came with the sat. these go bad all the time.
Posted on Apr 10, 2008
Sony 43"/projection (older) suddenly after 18 years has a snowy and less than perfect picture. It will "pop slightly" and the picture will come back to perfect. Any clue?
Your picture tubes are failing. There are no parts available for this TV and your money is better spent on a new flat panel. That is the grid guns starting to short out.
Apr 05, 2016 | Sony Televison & Video
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Jun 14, 2012 | GE 31GT660 TV
HI, i Have a 42" lg3000 lcd tv when I switch the
Hello, I have exactly the same problem with the exact same TV, white screen for about 15 minutes and than image appears perfect as if nothing happened. I have asked an ebayer which sells TV parts and he suggested it could be a main board or tcon board. I am quiet hesitant to fix my tv, but if the tcon board would fix it, i'd go for it. Did You manage to solve the problem yet?
Mar 29, 2011 | LG Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
One T.V. snowy on Sat., clear on local channels, others are fine?
if you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Apr 16, 2008 | DISH Network 311 DTV Receiver
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 36" Television
no unless U are capable of soldering within the tuner
Dec 10, 2006 | Toshiba 35A44 35" TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
