Question about Mtd 25B-520D200 CA Gas Lawn Edger
I have a Zama diaphragm carb from a Troy bilt trimmer. Factory guy said repair seat or get a new carb. Some one knows how to do that task and I sure would appreciate the knowledge! Thanks nmiller1
  • 61 Answers
Either 2 or 4 screws on the bottom of carb, remove them and the cover and you will see needle and seat. Remove one screw and needle will come out, There is a small spring under needle idler arm, do not lose it...
Be sure to mark which fuel lines go where before removing carb.
Posted on Apr 29, 2010
Testimonial: "Thanks for the reply! I have seen the seat! The problem is,, how to refinish or polish the seat so it won't leak anymore. Maybe impossible,,, there s"
  • sunneyskies May 09, 2010
    I've never heard of reworking a needle seat. It would be a lot less agravation to just buy a new carberator, unless you just enjoy fooling around with this stuff. Errrrr, those carbs cost about 35 bucks.
  • sunneyskies May 16, 2010
    I had the very same problem. Here's what i did. I used a samll drill and by hand, turned it on the bottom of the seat untill i could see a shiney mark all the way around the seat. Kinda like polishing a valve in. This worked great for me, but i did have a larger carberator to work with. Go slow and only take enough out to see a shiney spot all the way around.
    I have no leaks, and saved 175 bucks for not having to buy a new carb.
    good luck
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My Troy-Bilt trimmer Model TB20CS will not start....I have replaced the primer bulb, hoses to the carb and to the gas tank...I have replaced the spark plug...My next step is to replace all of the current...
You have done and are doing exactly what is necessary to solve your problem.
Lastly: remove your carburetor and clean it thoroughly using carburetor cleaner available at most auto parts stores. Replace the diaphragm and metering diaphragm. Diaphragms become stiff with age and with modern fuels and will not pull enough of a fuel-charge into the combustion chamber.
Sep 26, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Must run choke on all the time with troy bilt gas blower: 50:1
First I would check your fuel filter in the tank. They use a sintered type that clogs easily then allows dirt to get into the internal screen in the Zama carb, if the filter is clean and whole I suggest to take the carb out and clean it. Remenber to only use starting fluid to clean the internal parts, as carb cleaner will melt the internal check valves and ruine the carb. Dont be afraid to take the carb apart, its not brain surgery, just start with a nice clean shop cloth and lay it out as you take it apart. The screen I am referring to is on the metering diaphragm side, thats the side with one screw on it
Nov 01, 2009 | Troy-Bilt Mtd Southwest Tb320bv...
Need the carburetor assembly manual
It is either a Walbro or a Zama carb. I think both mfrgs have a website w/ parts breakdowns. But both carbs are the same as to the placement of diaphragms + gaskets. On the side with the inlet needle the gasket goes on first and then the metering diaphragm. On the fuel pump side the diaphragm goes against the carb body and then the gasket before the cover.
Aug 10, 2009 | Troy Garden
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weedeater just Idles
Carb needs to be adjusted or removed and cleaned with solvent.
Jul 09, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do you disasemble the head on the 4 cycle gas troy bilt trimmer
the head is bolted down by 4 torque bit screws some people call them star wrenches from the top but all plastic & carb needs to be removed more less everything to get to the bolts around the cylinder head as well as crankcase but to be honest its cheaper to buy a new one then repair it i had one repaired it & by the time i replaced everything i could have bought a new one cheaper then the parts cost me
Jul 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt in Hell String Trimmer TB465SS Running Problem
You need to clean the carb. or you may need to buy a carb. kit. But do a cleaning on it first. If you need tips on how to best do this, just let me know. Also check the fuel lines for cracks. As they age, they become brittle.
Jim
May 31, 2009 | Troy -Bilt String Trimmer/Blower...
I have a Troy Bilt weed eater and am having a problem. It starts with the choke on, but it will not run with the choke off.
Ths problem is possibly indicating the need for a new fuel pump diaghram in the Zama carburetor. A carb rebuild kit installed correctly should alleviate this problem and greatly improve throttle response on the unit. The ethanol in the fuel nowadays plays havoc on carb parts and they become less flexible and more brittle, thus affecting performance and leading to problems with throttle response and carburetor functions such as this.
May 08, 2009 | Troy Bilt Tb70ss Gas Trimmer
Trimmer is flooding.
It appears that the carb is not functioning properly. Sounds like the needle is not seating properly. It will need cleaning or repair.
Nov 16, 2008 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Mtd 25B-520D200 CA Gas Lawn Edger Logo
177 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
