Question about HP vp17 Monitor
How do you get rid of the no s-video input signal in the corner of the monitor screen
  • 1894 Answers
SOURCE: monitor
try a different input cable and check if this is a cable or some loose connection problem.
that itself may get the problem solved many times.
Posted on Aug 01, 2008
venexcsd
  • 1185 Answers
SOURCE: monitor says: no signal input check video cable .
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Posted on Jun 27, 2009
  • 1481 Answers
SOURCE: I have a Hannspree 25 lcd monitor and I can't get
the monitor is not properly connected to the back of the PC box, check the cable that goes from the monitor to the PC box, (first unplug the PC/monitors from the power socket)
check if the cable is loose from the monitor jack point on the back of the PC box, remove it and blow air in it may be some dust is there.
fix it back and tighten the two screwes with a screw driver.
power it back ON
Posted on Dec 07, 2009
joecoolvette
  • 5660 Answers
SOURCE: my monitor cannot pick up signal.
If your monitor displays No Signal, it means there is no video signal coming from the computer. Monitor is working fine.
It may just be the monitor cable. Do you have another one, or one you can borrow from another computer, for a test?
If a known, good, working, monitor cable yields the same results, the problem is your computer.
The computer isn't working.
The problem may be due to the power supply. Most of the time it is.
This statement is given because of,
A) Most of the computers that come to my shop, have this problem.
B) If you look on the internet, it is a common problem stated.
C) Most of the problems on here, are due to power supply issues with the computer.
You may see, or hear fans spin. Lights light, and it may sound like the harddrive is running.
Problem is, the processor doesn't have enough power to operate, so nothing is going to get done.
The main rating for power of a power supply is Watts.
Voltage times Amperage = Watts.
1) ALL the lights use less than 1 Watt
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 55 to 125 Watts.
Depends on what processor it is.
The power supply has 3 main voltage power rails.
A) The 3.3 Volt rail
B) The 5 Volt rail
C) The 12 Volt rail
If the power supply develops a weak, or failed voltage rail, the Processor does not get enough power. Won't turn on.
Most of the time a power supply fails because it is dirty inside. (And the inside of the computer)
The simple solution is to unplug the computer from power, open the computer case, and use a can of compressed air for computers, on a regular basis.
Install the plastic 'straw' into the nozzle, and shoot air into the inside of the computer in rows.
Start at the top inside part of the computer, going from one side, towards the other side.
Then go down towards the bottom.
Tip the case slightly with one hand, and use the other hand to shoot air towards the bottom, to remove the remaining dust/dirt.
Shoot air into the power supply, from the back of the power supply through the ventilation holes. (Inside of computer)
Use a few Q-tips, and clean the fan blades, center hub, and surrounding cage, of the power supply fan, then use air. (Back of computer)
The rest of the time the fault lies in bad Electrolytic Capacitors inside the power supply.
CAUTION!!
NEVER open a computer power supply!
The Electrolytic Capacitors inside, hold a charge for Weeks, sometimes Months, after the power supply has been unhooked from power!
You can get shocked Badly, or even Fatally!
Best solution is to replace the power supply. If you have another working power supply, you could use it for a test.
[Be sure to work on a table. Be SURE to touch the metal frame of the computer case, (Case open),
BEFORE you reach inside!
(Computer UNPLUGGED from power)
Your body carried Static electricity. Static can fry out computer hardware components, in a New York second!
Computer unplugged from power you're safe.
Touch the metal frame before reaching inside, the computer is safe.
If you get up for any reason, leave, then return, touch the metal frame again!]
Posted on Jan 03, 2010
  • 95 Answers
SOURCE: Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
Below is a link that may help you...Good luck http://www.techspot.com/vb/all/windows/t-35070-DVI-to-DVI--No-Signal-on-LCD.html
Posted on Apr 06, 2010
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
What should I do because it says no signal input
Sounds like your video card or monitor is bad. Most likely it's the video card because if it was the monitor the No Signal Input could not appear on the screen. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed Monitor displays ok without a problem then your original monitor is bad. If the Borrowed monitor has the same issue of No Input Signal as your original monitor, then your video card inside the computer is bad.
May 30, 2012 | Biostar MCP6PB M2+ Motherboard
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
My monitor came up with a corner blue screen and inside it said NO composite input signal. I cannot delete it or minimize it. What does the message mean and how do I get rid of it
Move mouse or hit any key on the keyboard on the computer or activate video player, then access the OSD to set Audio to “ off ” state.
if that does not work
check in bios if we are getting the same screen
if yes then it`s time to get the monitor replaced
Sep 18, 2009 | Computers & Internet
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Apr 30, 2009 | HP vp17 Monitor
No composite input signal
Try the following:
Right after power on, tap the F8 key to see if you can get a short menu to come up.
If it does, select "Safe Mode."
If your screen looks different, it may be just the driver for the display card or monitor is trashed (Windows like doing that, keeps us challenged).
- Open Control Panel, then System, then Hardware, finally Device Manager.
- Locate Display adaptors, open and delete the adaptor listed (all, if more than one.)     - Locate Monitors, open, delete any listing there.
Reboot.
Windows should 'find' two 'new' devices and install the drivers for them.
The display may still be different if you had other than the default settings.
Go then to the Display folder of the Control Panel, click on 'Settings' and experiment. Depending on your Windows version, if you choose something dumb so it makes the screen unreadable, ignore it and Win will ask if you want to keep it and give you some time to acknowledge that you like it. When you don't, it will just go back to the pre-tinkering settings.
Apr 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
HP vp17 Monitor Logo
621 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
