Question about Minolta EP4000/5000 CS/PRO Copier
What does this code mean COB63 or C0B63? - Minolta EP4000/5000 CS/PRO Copier
  • 1,110 Answers
Sorter error code. Almost always this code will reset. You must pull the sorter away from the copier then close it back to reset this code. The normal open/close the front door will not work.
Posted on Apr 29, 2010
Code error
If the Nokia 7210 says Code error means you entered the wrong code,It's Network Unlock code or security Unlock code?Network unlock code means you can have only 5 Unlocking tries ,if you missed means it get hard locked ,so cannot unlock using the unlock code,get the correct Unlock code from the site
Unlock-free.com/nokia/nokia-7210.html and Unlock from Network lock,You need to unlock from security or password lock means get the master reset code for Nokia 7210 at here and reset it.You can also try default code 12345 or 1234 or 0000 if not works means get the master reset code and reset it.
Dec 12, 2011 | Nokia 7210
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
Nov 11, 2010 | Minolta EP4000/5000 CS/PRO Copier
I ahve an error code c0b63
It is on sorter stapler error.Disconnect the sorter unit and is OK.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Guest Konica CSPro-EP4000 Error code is COB63
All COB codes no matter the number are sorter error codes. You must open then close the sorter in order to clear this code. By opening and closing I mean you need to pull the sorter away from the copier then close it back.
Apr 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code cob63
sorter malfunction reset by pulling unit away from machine . If resettable , you can unplug and remove from system - install exit tray
Feb 15, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code cob63
clean or replace lower limit sensor in sorter.
hope this helps
May 30, 2009 | Office Equipment & Supplies
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep4000 sorter bin is stuck. code is
how to solve cob60 error in minolita 3000
Feb 17, 2009 | Canon imageRUNNER C3200 Copier
Error code C0B63
All C0b** codes are related to the sorter. A C0b63 is a malfunction of the bin lower limit position sensor PC2. Most likely it is a broken bin.
Nov 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
114 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
