Question about HP Compaq Presario SR2032X PC Desktop
Problem with onboard video of a compaq sr2032x
I am working on a friends computer whos son yanked the monitor and broke the onboard video connection I am trying to install a pci card but since I can't see whats there i can't get into the bios to disable the onboard video. Anyone know how can disable the onboard without getting into the bios?
    Problem Solver:
  • 14 Answers
The onboard video card is actually set to secondary when you plug in a PCI or PCI-E video card. If no video image is showing then there may be further damage inside the mother board.
Posted on Apr 29, 2010
Why screen not coming on
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 06, 2014 | Compaq Presario S6700NX (DQ182A#ABA) PC...
Why won't my COMPAQ PRESARIO SR2032X desk top
Please turn off the computer, start hitting F8 at the start-up and then choose last known good configuration. If this does not work, choose Safe mode options.
If still does not work, please try to restore the computer to factory settings. You can try to hit F11 or F10 at the startup to initiate recovery.
If not working, please tell me what error message you get on the screen.
Jun 01, 2013 | Computers & Internet
I have a ASUS P5GL-MX motherboard. When I turn on the computer I see nothing on the monitor. I had the opportunity to get my keyboard, mouse, monitor and even the memory checked out to make sure they are...
The operation of the onboard video is programmed into the board, so it should work without any drivers being needed. If you verified that the monitor is working then I'd say the onboard video had gone bad. Your motherboard has a PCIe x 16 slot so you can get around the problem by adding an aftermarket video card. The cheapest of them have quality that surpasses any onboard video and they can be found almost anywhere. Follow this link to see some suggestions.
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_13067_13067
Oct 17, 2010 | ASUS P5GL-MX Motherboard
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Is this a MS-7184 problem? My son's computer has a wavy screen, so I replaced the CRT monitor with a new flat screen. Still wavy. Next, I replaced the onboard video card with a PCI card and nothing shows...
you need to install drivers with the new video card but first you must uninstall the old one-definately a driver issue(assuming all cables are good,etc)
Sep 15, 2009 | HP Compaq Presario SR1620NX...
The monitor doesn't go on. the orange standby light blinks on and off. is there a reset?
Sounds like the issue is with your video card/onboard video chip or the connection between the monitor and the pc. Verify the cable from the monitor is connected to the pc firmly & snugly. See if the monitor gets a picture on a known working pc. If so, then it's a (relatively) simple fix - work on the videocard - if add-in, try reloading drivers, ensure the onboard video is disabled in the BIOS, or (worst case) replace the video card. If it's onboard, again, try replacing/updating drivers and, if that fails your next step is to either get an add-in video card, or replace the mobo.
Aug 13, 2009 | LaCie Electron III 22" CRT Monitor
Can't get Picture on Monitor, replaced video card
Boot up into the setup, usually F2- in the video section look to be able to make a change from Onboard to PCI ...apply-save change and exit ...also make sure you have connected the monitor to the correct area...I , like a big dummy, have often just hooked it up to the first blue socket i saw and of course...not much happens.
I hope this helps you Fred, (if it came with drivers install them)
please leave rating, thank you kindly
May 04, 2009 | HP Compaq Presario Media Center SR1750NX...
No video at all on Compaq ProLiant 1850R
Do the server has an onboard Video disable the video in the BIOS setup insert another PCI Video card and check for the display , IF the PCI display is up then there could be a problem with Onboard card.
Nov 27, 2008 | HP Compaq ProLiant 1850R Server
Sometimes my Compaq laptop computer screen gets all pink and pixley. It is like a magenta pink. It dosen't do it everytime just randomly but sometime I cannot get it to go away. Sometime when I would...
It sounds as if the culprit here is going to be either the screen itself, or the video card. On a desktop PC, this would be fairly simple to troubleshoot because you could switch out the monitor with one that is known to be working properly. If that did not solve the problem, you would next need to look at your video card. If the computer had onboard video, you could install an aftermarket video card and disable the onboard video.
Unfortunately, with a laptop it isn't quite that simple and you will more than likely have to take the unit to a professional repair service.
Graye
Nov 26, 2008 | Compaq Computers & Internet
I need help
make sure you have the correct drivers installed by going to device manager in control panel..... if you have then you'll need a better graphics card as yours is prob onboard using system memory with a limited output in resolution
May 23, 2008 | Dell E173FPb 17" TFT LCD Monitor
HP Compaq Presario SR2032X PC Desktop Logo
336 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
