Question about RCA P52926 52" Rear Projection Television
Cap. blow on my RCA D52W23 the power board and burned hole though it
And need to know where i can buy a new one or can it be fixed have a picture of blowen cap it wont load it's to big
  • RCA Master
  • 8,617 Answers
I am not understanding what you are needing to replace. Is it a capacitor? Can you give me the chassis number of the TV as well as the number of the component thaat is stamped on the circuit board next to the blown cap such as c1254. I should be able to help you if you can provide that info.
Posted on Mar 24, 2008
SOURCE:
My rca tv green light comes on and then goes off repeatedly. the picture will not come on the screen, could this be the color wheel? if it is where is it located in the tv and where can i get it?
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 13, 2010 | RCA D52W23 52" HDTV CRT TV
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
Rgb will not align
Go to Menu then to setup do you see convergence Listed ,if you do not then you have a Blowed Fused
FL231 it will be Located on Deflection board on right hand side of FBT flyback Transfomer there is 3 in a roll they are small looking brown rectrangler caps it will be the one in the Middle, These are Fuses.06 volt
Partstore.com has them. Let me know if you need more help.
Mar 23, 2010 | RCA D52W23 52" HDTV CRT TV
We have a RCA D52w23 rear projection tv that powers off.
most likley the deflection board is at issue. Thats the number one board which fails in that chassis.
Mar 15, 2010 | RCA D52W23 52" HDTV CRT TV
Replaced deflection pwr board on rca d52w23 projection tv and still no pwr at all ( this board had a burnt cap) please advise
is that voltage traceable  on that ckt when power on, forward that trace to horizontal area may be there's part open resulting your machine dead.
Feb 23, 2010 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
RCA HDTV D52W23- words in 3D - picture at top and bottom black
are you still having this prob? i am having a similar prob with the same brand of tv. if you had yours fixed please help me with mine.
i think it is the convergence ic. i need three ic but the distributer will nit sell no less than ten of them. if you or anyone need any of those ic i could let you some for the same unit price i bought them. posted 09/02/2009
Jun 28, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 Color Alignment. Blue,Red,and
Its problem of convergence board and need to be replaced. You can buy this board at Part Store.
Please replace the board if you have basic electronics knowledge or get help of tech person.
Regards,
Sep 19, 2008 | Televison & Video
RCA P52926 52" Rear Projection Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
