Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon pixma all in one mp500 error code 6A00
Canon pixma mp500 error code 6A00 occurs when the printer is turned on. Printer will not respond to anything I have tryed. Was on Canon website. What is the printer telling me?
    President:
  • 2,049 Answers
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Posted on Apr 29, 2010
Error code 6a00
Error code 6A00 means an error occurred in the AP motor during purging operation. You will need to replace the sheet feed unit (part no. QM2-2916), logic board assy (part no.QM2-3078), purge unit (part no. QM2-2925).
Feb 12, 2011 | Canon Pixma MP500 All-In-One InkJet...
Printer has error code 6A00. What does that mean?
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Purge unit (QM2-2925).
Jan 20, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00 when you turn printer on
AP position error causes the 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board assy (QM2-3078), Purge unit (QM2-2925).
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
I have an error code of 6A00. I dont know what this is and how to correct it
AP position error [6A00] means that an error occurred in the AP motor during
purging operation.
The fault part may be:
- Sheet feed unit (QM2-2916)
- Logic board ***'y (QM2-3078)*1
- Purge unit (QM2-2925)
you better contact a tech because it is not that simple to fix if you have no tech expirience.
Nov 18, 2010 | Canon Pixma MP500 All-In-One InkJet...
Pixma MP500 has a ERROR code 6A00 and the printer
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500
Hello my friend, check if print head carriage has stuck and move the carriage a few times. You can also blew some compressed air around to clear any foreign objects.Also you can try moving the cartridge back and forth a few times and when you do that restart your printer .If still doesn't work you should take it to a repair shop.Good luck:)
Feb 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
6A00
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Oct 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
Pixma error code 6A00
Dear luis,
Your printer has paper feed related error. There are 2 possibilities of this errror: Auto sheet feeder or logic board faulty. Then you need to replace these parts.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 error 5400
Please l have a problem with my printer whenever l want to Print an error code always comes up on the Screen ERROR CODE 6A00 what should l do
Oct 12, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
651 people viewed this question
old marine
old marine
