Question about Acer TravelMate 2300 Notebook
Some keys work some dont
My daughters 2410 was working ok she cleaned the keypad now only certain keys will work others wont not cleaned with any liquid just a dry cloth is it easy to fix or will i need a new keypad ? how and where can i get one if needed thanks
shaun
    Problem Solver:
  • 16 Answers
You can probably find a keyboard on Ebay that will fit you computer. It is not difficult to change the keyboard, but it does require some expertise.
As a temporary solution you can use an external USB keyboard or a wireless keyboard. They are readily available.
Posted on Mar 25, 2008
Melcom ST6000 key pad not working on a certain
Are you having problem typing certain numbers on the keypad? Please state you questions a bit more detail.
Commonly, like yesterday, I fixed my niece's keypad by just cleaning.
The procedure is as follows: Power down your machine, unplug the keypad from the machine.
First blow the keypad with a hair dryer without the heat or a blower. This would remove the dust and.
Now take a medium size brush and brush those keys taking the keypad upside down. While doing this tap the backside of the keypad time to time.
The next thing is a bit scary. But if you do it right this is best. Spray some Windex on the keypad and use a tissue paper or a cleaning cloth and clean the keypad on and between the keys.
This solved my niece's keypad.
Hope this helps you too.
Oct 15, 2014 | Computers & Internet
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
Travelmate 2410 keys not working
You don't need any drivers. Laptops and desktops use an internal win device driver. You can actually find the file called keyboard.sys
What you need in your case in a new keyboard. For your Travelmate they sell for about $50. It takes maybe 10 minutes to change it out. This is something you can do at home. Look on you tube for something like laptop keyboard replace and you can see the process and decide if it is something worth trying. If you google or bing or whatever for travelmate 2410 keyboard or laptop parts you can find several dozen sources. If you look they will have instructions or videos for your travelmate.
Sep 06, 2012 | Acer TravelMate 2300 Notebook
It won't dial
Check phone liquid ingress keypad connector to main board,swap another flip,if ok,replace keypad or display.
Aug 17, 2009 | Motorola Mobility RAZR V3
Keypad dosent work on my samsung SGH E315
hi im josh in cebu phils.friend may i help you? Friend the problem when the key pad wont work is the connection your keypad board or dome to the main board.all you have to do are: 1. open your phone with T6 screwdriver for phone and clean the key pad mat or board or dome with a soft pencil eraser and a small brush like tooth brush. 2. check the wire of the key pad connection be sure it has no moist ect. 3. check the keypad IC. if detached re solder it. 4. if you dont have the skills of doing these or if dont want to risk. you let the phone service center do the job.  thats all hope i helped you.good luck
Mar 14, 2009 | Samsung SGH-e315
HTC Dash Keypad Problem (some keys dont work consistently)
Wow. That is an old phone. Replacement parts probably will cost more than another phone
Mar 07, 2018 | T-Mobile Dash Smartphone
Certain keys not working
replace key board old one going bad mabey needs cleaning with dust out can
Jan 02, 2009 | Dell Computers & Internet
Key pad
open the front key face by placing a card on the side of the phone. careful not to poke it harder as there are some chips inside the front slide. once it is open, clean it or try to adjust the keypad face then place it back. If problem still exist, bring it to the mobile center for repair.
Apr 09, 2008 | Nokia N81 Smartphone
Avaya 2410 speakerphone
If the phone programming has been set to 2-way and you have reset the phone. Either by unplugging it and waiting for a few minutes then plugging it back in or from the idle state press the "MUTE" key and then dial R E S E T on the keypad. If after this it will still not work as 2 way then it is most likely a faulty phone.
Jan 24, 2008 | Avaya 2410 Corded Phone
Nokia 7280 - keys dont work
there is a flex cable with all keys on it.you have to change it.this is offen problem with this model.it cost aroud $20
Aug 08, 2007 | Nokia 7280
Computers & Internet Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
