Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Is the PIN on the bottom of the router the same as the WEP or WPA?
  • 550 Answers
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA.
To check the wireless network key ( WEP / WPA) you will need to access the router settings page.
On that page , you will find all the settings of the router.
Posted on Apr 29, 2010
2 Suggested Answers
  • 54 Answers
SOURCE: belkin wireless adapter thinks router is WEP but its WPA
Try reseting it, if that doesnt work, then tell me, so I can help you step by step.
Posted on Jan 12, 2009
I don't know my wpa key
Click on the link below to find the WEP/WPA key of your router.
Find WEP/WPA key
To know your default Router Gateway IP follow the instructions
Click on Start button ( on your PC -> bottom left corner )
Click on Run or Enter in Search button
Type "Command" ( without quotes ) and hit enter key
In the black Window, Enter "IPCONFIG" ( without Quotes ) and hit enter
It will display the network details, Look for Default Gateway, That is your Router IP Address.
Regards,
Sean
Jun 09, 2013 | Belkin Computers & Internet
Where do i find network key?
Follow these steps:
1. Open Internet Explorer then type the numbers 192.168.1.1 on the address bar then press enter.2. Make sure that the pc is connected via hard wired connection.3. After typing the numbers on the address bar, the site should be on the modem settings page.4. Go to basic settings or look for the Wireless Tab then select and browse thru it.5. Under SSID, there will be security option, check if you are using the WEP or WPA security key.6. Whatever the WEP or WPA key is, that is your network key. Since you are already on the said tab, it will be better if you are going to retype or change the WPA - Pre Shared Key and make sure that you will remember whatever the Pre Sahred Key you used.7. Select Save and apply then exit.8. You are good to go then, using your network key..
Thank you and kindly rate this post.
Jan 02, 2012 | Vizio XWR100 Wireless Router
Which # on the bottom of my actiontec is the WEP #?
The WEP encryption key is setup by the user, it is not a fixed key.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 10, 2011 | Actiontec GT704WG Wireless Router...
What is the pin
The pin or the encryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Apr 16, 2011 | NetGear WGR614 Wireless Router
What is the pin?
Pin is basically the password of the router wep/wpa which protect the wireless router from other people to use your network or internet conenction. If you enable the wep/wpa passphase it will set security lock and will prevent other people to use your conenction.
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
How do i find my SSID, WEP key and WPA key trying to connect ps3 to internet.
You need to log onto your router and determine the WEP or WPA key being used. Your router manual has logon details. Also, the key is sometimes on the bottom of the router.
Aug 06, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
Pin number
you can get the pin number by contacting the provider.
Jun 30, 2010 | Linksys Wireless-G Broadband Router
Followed instructions from Best Solution posted on Nov 19, 2009 by bhuvan25. When got to: Encryption:-WEP for wep security TKIP/AES for WPA-PSK. Network key/Confirm network key:-is the wep key or wpa-psk...
If you select WPA security mode then you can not add the network manually.
I think the OS on your computer is windows XP.
You can connect to the netwoek using the windws utility.
If you select WEP, then you can add the network manually.
Click here for more information about router and networking
Feb 16, 2010 | Computers & Internet
Connection is asking for network security pin
Network Security pin is the WEP or WPA provided by your service provider, while configuring the Router. Please follow the below steps to get the WEP key.
1. Click Start -> Run -> type "cmd". Click OK. Command prompt screen will popup.
2. In the command prompt type "ipconfig" hit Enter.
3. Please make note of default gateway address (Eg. 192.168.1.1)
4. Open internet browser and type http://<default gateway address> (Eg. http://192.168.1.1)
5. You will be prompted to enter Router login Username and Password. (provided by service provider). Enter the username and password.
6. You will see the Router configuration page, then select the Wireless Tab; there you will see WEP / WPA key.
Thanks n Regards
Rizwan
Jan 28, 2010 | Computers & Internet
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
483 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
