Question about Whirlpool DU1055XTS Built-in Dishwasher
Did not drain all the way and will not turn on.
Door closes but wash option buttons do not work.
  • 33 Answers
Your clip is broke that's what tells it is closed
Posted on Apr 29, 2010
How to fixed a error code E43 of washing machine Siemens
This is related to the motor, and may be that the motor needs new brushes the Tacho (feedback mechanism) is broken, wiring or the motor control board. Most likely for a 6-7 year old washing machine is the brushes.
However, after changing them, you still need to reset the machine
  1. Turn off the machine (dial to 0)
  2. Open the door
  3. Turn on the machine on first program
  4. Close the door
  5. Turn off the machine
  6. Turn on the machine on the "six-o-clock" program, which is centrifuge
  7. Press the "option down" button and keep it pressed (This is the button left of the display)
  8. Turn the dial to "seven-o-clock" (empty/pump out program)
  9. Release the "option down" button
  10. Turn of the machine
This should reset the machine, and if everything is allright, it should work. If it does not work after changing the brushes and resetting it, something else is wrong, most likely the motor control board, or if the motor.
Oct 08, 2016 | Siemens Washing Machines
Can you open the door to begin wash cycle and then close which will allow you to mount flush with cabinets?
Actually, I think it is designed to do that - select your wash cycle and options with the door open, then press Start, and then close the door within 3 seconds and it should run.
Dec 13, 2014 | KitchenAid KDTE204DWH Architect II Superba...
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
Clean light flashes
I have found 2 possible solutions for you to try on your washer. It looks like there are good results on each of the sequences listed so you may try both to see what one works for you.
1) Press normal wash and heated dry one after the other about 5 times.All lights on panel will light.Wait until all lights go out and it resets itself.It will go into a mode on it's own.Then press cancel and set your options as you normally would and press start
On the hidden button models this seems to work, push these buttons in this order:
Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash, close the door, Start, open the door, Cancel 2x
Mar 08, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Hi, I have a duet washer that won't turn on. The "Control On" button is blinking and when I press the "Hold to Start" button, nothing happens. And ideas?
Open and close the door.
The door has to be opened between wash cycles.
Check the door switch/lock unit
using the diagnostics listed below.
If door is locked, Drain the unit.
Check wire harness for connections.
Check the touchpad/LED assembly.
Starting the test mode:
Close the door
Press Control On button
Select the DRAIN/SPIN cycle
Select NO SPIN by pressing the SPIN SELECT button,as needed,
Push Prewash Option button 4 times within 5 secs.
C:00 will show in the display.
To advance to the next step
Push Prewash Option button 2 times.
Here are the codes:
C:00 check door lock system actuator
C:01 Check cold water inlet valve flowmeter
C:02 check dispenser motor
C:03 check hot water dispenser
C:04 check basket rotation MCU,Motor
C:05 check heater sensor
C:06 check Drain pump
C:07 check Motor or motor control unit
C:08 check Motor, MCU control
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Whirlpool DU1055XTS Built-in Dishwasher Logo
71 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
