Question about Cycling
I'm renting a live/work space 25' x 25' with 15' cathedral ceiling and 42" knee walls. The owner bought new a Jotul B Vent Allagash, but installed it himself with the help of a plumber friend. The installation involves an extension 7" beyond the knee wall into the room because the alcove that houses the vent doesn't offer enough clearance. The extension measures 22" horizontally then elbows up into the vent that extends several feet above the slanted roof, but not beyond the peak. The extension appears to conform to the Jotul manual criteria for alternative installation configurations. I have pics. The stove hasn't worked properly since they installed it and converted it to propane. The owner claims he can only get it to work if he "bypasses a sensor". Prior to that, the stove would cut out after 20 mins - 2 hrs or get very sooty. Propane isn't supposed to generate soot, right? Also, the slight smell of gas worried me. With the bypass, it seemed to work well enough but at some point the smell became very strong and I shut off the gas at the valve in a panic. In retrospect, the tank could have been low at that point. I haven't dared fire it up since. The owner refuses to have the shop where they bought the stove send a service technician unless they agree to a free visit upfront. The store won't agree to that until they take a look. The independent service techie that I described the situation to thinks the installation may be the issue. In the meantime, as the tenant, I am COLD and running up the elec bill with a space heater and the landlord thinks I should pay!!! What to do???
  • tinawendon Apr 29, 2010
    Wow, thank you SO much!!
    Great idea, I'll do it tomorrow! The landlord purchased a smoke detector but never got around to installing it!
    Guru:
  • 416 Answers
Can't tell you what to do, but I will tell you this. I have a propane "ventless" gas fireplace. It was installed by my building contractor. From day 1 it produced fumes and soot. After about an hour, the flame would actually go out. I got ********** one day and started riping into it. I found a plate that was not adjusted correctly. Basically the fire wasn't breathing. So, with that said... I believe it's the installation. It sounds just like it's doing the same thing, sufficating. As far as the Landlord... have a lawyer contact him. That should be all it takes.
Posted on Apr 29, 2010
  • Adam Halfhill
    Adam Halfhill Apr 29, 2010
    Also, for safety. Regardless of the outcome... get a CO monitor installed. Ventless or not, if it's burning fuel, it's creating gases. Be safe and protect yourself.
How much should i charge for painting a two bedroom apt. Inteior only. walls and cealing two bath one living room kitchen and laundry room
About 50 cents a square foot would be a reasonable price for a straightforward paint job (no stairs, cathedral ceilings or furniture to move).
May 28, 2014 | Measuring Tools & Sensors
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
What's your problem?I WANT TO INSTALL A DOWNLIGHT BUT THERE ARE 8 WIRES COMING FROM THE CEILING WHAT GOES WHERE?
Connect to live and neutral, cap other wires and see what happens.
If you have 2 live wires, you might have 3-way switch
Nov 13, 2011 | Home
I Have A Cozy Space Heater And It Will Work For Awhile Then Goes Out, Relight The Pilot It Stays On Turn The Heater On And It Will Work Awhile Then It Shuts Off Again
if you have the vent pipe in a chimmney or vented outside wall can cause this problem, need to either put a liner in chimmney or vent insde the room with the heater up thru the ceiling.
Oct 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
Live in a two story home with cathedral ceilings and the vent in the master bedroom upstairs isn't blowing any air what should i do?
First thing is to make sure somehow the vent didn't accidentally get closed. If that is not the case, then you might either have a restriction in that vent; a leak in that vent; or a leak in the trunk going back to and into the furnace. Take a look at the ducting (where it can be seen) and repair any obvious damage. Also.. don't forget to check for dampers in the "room" with the furnace. I have seen these moved in the past, and are often at fault. Hope this helps.
Jul 11, 2009 | Honeywell HE220A1019 Whole House...
Tankless water heater venting
You get a wall vent for that heater. This room is not inclose is it?If not then wall vent would work just find.
Mar 14, 2009 | Rheem RTG74DVN Direct Vent Natural Gas...
I am living in a home with a carrier furnace. The furnace is in the back part of the house in a store room. It has two- 2 1/2 inch plastic pipes. One that suppplies air to the furnace and the other is...
As long as the fresh air intake pipe to the furnace is not plugged up the second vent is not needed some homes when they are new are air tight and need a fresh air circulation system
Oct 30, 2008 | Carrier Heating & Cooling
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Cycling Logo
22 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
